coolant leak under header 305 tpi
Old May 18, 2014 | 12:23 AM
01limited's Avatar
Been lurking on the forum for awhile and thankfully haven't had any major problems with the car. But I have an 87 TA with the 305 tpi, coming into work I had some coolant hitting the header and smoking up it appears to be coming from where this line goes into the motor. What exactly is this line. Hopefully you can tell from these pictures.
Attached Thumbnails coolant leak under header 305 tpi-photo-1.jpg   coolant leak under header 305 tpi-photo-4.jpg   coolant leak under header 305 tpi-photo-2.jpg
Old May 18, 2014 | 03:05 AM
01limited's Avatar
Re: coolant leak under header 305 tpi
If better pictures are needed I can try to get them when I get home in a few hours. Just a tight space to work in
Old May 18, 2014 | 06:29 AM
01limited's Avatar
Found the culprit in the day light. Pin hole in a heater hose, im guessing thats what the hose is anyways.
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
