Cooling Fan Wiring Help
Old Jun 19, 2014 | 11:25 PM
addition413's Avatar
Alright I have a head scratcher. I am working on an 86 camaro with a 305 TPI. When I got the car the front was crunched and since I had the replacement parts I went for it. I now have everything back together and I am trying to get the cooling fans working. From what I found on here this car should only have one cooling fan but it has 2. I am not sure if this was a mod or if it came factory this way. Either way I figured out the passenger side fan with help from here but I am stumped on the drivers side fan.
There are currently 2 relays that control the fans and both are mounted on the radiator support. The passenger side fan is controlled by a temp switch between cylinders 6 and 8. All seems well with this one. The part that has me baffled on the drivers side fan is that when I test the leads to the fan motor it has 4 volts between the terminals. When I unplug the second relay the power goes away and I still have not figured out how to get 12 volts to the fan. Seems like something is shorted but after going through the first wire harness I found nothing to fix this. Also when I check out schematics they do not help because this car should not have 2 fans.
In addition I have a code 33 on the ecm so I am not sure if the 2 are related. Any help in troubleshooting would be greatly appreciated.
Old Jun 20, 2014 | 01:52 PM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Re: Cooling Fan Wiring Help
I wonder if they are RamCharger style dodge dual fans? I build them for a lot of GM applications since they fit a lot of 31x19 radiators very well. Post a pic up of what you're dealing with.
Old Jun 20, 2014 | 11:27 PM
[quote=formula1LE;5780851]I wonder if they are RamCharger style dodge dual fans? I build them for a lot of GM applications since they fit a lot of 31x19 radiators very well. Post a pic up of what you're dealing with.
Below is a picture of the fans. There are 2 relays. Both are mounted to the side of the radiator support on the battery side.
Old Jun 29, 2014 | 10:12 AM
hilltop530's Avatar
Car: 1987 Iroc Z28 Camaro
Engine: 5.7 TPI
Those look like the OE fans. The passenger side fan should run off the fan switch between cylinder 6 and 8 and, the other won't turn on until the car gets hot. that's when you should see the voltage at the relay.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
Leggman1
Aug 6, 2015 04:15 AM
