Single stock fan size on TBI cars?
Old Jun 29, 2014 | 12:03 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I looked couldn't find the size, anyone know the curent draw and cfm by chance as well? Thx
Old Jun 29, 2014 | 01:50 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: Single stock fan size on TBI cars?
IDK the answer to your question. But if you need to replace a missing fan, I would go aftermarket and get the biggest diameter fan you can fit, wire it from the stock relay if you have one, or build a relay circuit with a thermocouple if you don't. Search in here and you will find how to threads on the subject.
Old Jun 29, 2014 | 07:02 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Here's a circuit you can use including if you decide to use a large fan with a high amp draw .It is totally independent from any stock wiring.
(the stock wiring and relay is to small for a hi amp draw)
This is the temperature controlled adjustable fan controller. You might need to punch in the part number. = # 733653
http://www.autozone.com/autozone/par...67187_69565_0_
I have two fans with a 180* thermostat. One on at 190* and the second at 200* as backup.
MustangBeater20
Oct 29, 2022 09:20 PM
Linson
Aug 21, 2015 02:12 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
Leggman1
Aug 6, 2015 04:15 AM
MENINBLK
Aug 5, 2015 11:58 PM
