fan nightmare
Old Jul 13, 2014 | 05:13 PM
1985chevydude's Avatar
Car: 1985 chevy camaro,z28
Engine: crate 350,headers,3in exhaust
Axle/Gears: 308------3.73 auburn unit
fan nightmare
Hi everyone
i have a 1985 z28 camaro,with a fan switch issue,the switch gets blistering hot after only about 5 minutes runing.
i checked the grounds,all the wires witch is only the ground,power ,and accesory,all are not damaged.yet it still gets hot.
any suggestons?
could it be my fan is on its way out?
and i was also wondering what size fuse the factory would have used for the fan,because i have a 25 amp fuse and it dosent blow it but like i said the switch gets way to hot.
Old Jul 14, 2014 | 03:48 AM
clown69's Avatar
Car: 1990 Camaro RS
Engine: V8 305
Re: fan nightmare
The wire might be to thin go with a thicker wire
Old Jul 14, 2014 | 06:23 AM
Re: fan nightmare
The fan switch is mounted in the pass side head.
How do you know it gets unusually hot?
Old Jul 19, 2014 | 07:18 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: fan nightmare
isn't the 85 single fan system controlled by the ECM? I don't think they have a fan switch stock. BUT after 16 mooseheads ,I could be wrong
Old Jul 19, 2014 | 11:22 AM
TBRays98's Avatar
Car: 1989 Formula
Axle/Gears: 3.45 1LE Disc LSD
Re: fan nightmare
Yea there is not a fan switch for the 85's, factory that is. Take a picture of what youre talking about. There should be two wires off the single fan. One is ground and one is to the fan relay. The relay leads to the ecm.
Old Jul 19, 2014 | 06:25 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: fan nightmare
After being here for 8 years I have heard what seems to be a "thousand" complaints about the switch in the head and or car running to hot = stock thermostat + head fan switch/ECM controlled being set high.
Here's an option to remedy that/those
Post # 23 in this thread. =
https://www.thirdgen.org/forums/cool...ml#post5794397
I also have simple circuits for larger/higher amp fans that are totally independent of any other wiring including the stock.
That's how mine are set up.
Old Jul 21, 2014 | 10:51 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: fan nightmare
I want to say all single fan systems use the fan switch in the head and only the dual fan set ups use the ECM cooling feature.
Old Jul 21, 2014 | 11:02 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: fan nightmare
Could 1985chevydude be talking about a " manual switch" he has mounted in the car for activating the fan/fans and not the switch on the head?
Old Jul 21, 2014 | 11:46 AM
Car: 86 IROC
Engine: 5.0 TPI
Re: fan nightmare
nah ,you got it back wards.the dual fan set up uses the switch in the right head. the previous single fan is controlled by the ECM thru the fan relay
Old Jul 21, 2014 | 01:16 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Re: fan nightmare
My 84 single fan doesn't use the ECM at all, only the fan switch in the head to control the fan.
Old Jul 21, 2014 | 05:22 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Direct-Connect ▬—––—▬ But Not Mopar
It sounds like you’re talking about a driver controlled switch, not any one that might have been mounted in the engine.
Even if an aftermarket switch was retrofitted to the engine, the switch still needs to power a relay, not the fan directly.
Happy Racing !
I Didn’t Jump The Start, The Flagman Was Late
Old Aug 6, 2014 | 10:02 PM
Re: fan nightmare
Sorry Bout not getting back fellas.
I said screw it put a new thermostat and bought a fan motor and temp setup that is plugged into the water neck.
Seems to be working great.
Im jealous my dad has 60's muscle cars and they seems alot more senseable
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
