Oil Cooler
Old Jul 18, 2014 | 08:58 AM
Termanalor117's Avatar
Car: 1991 Pontiac Firebird Trans Am
Engine: 1987 Chevy 355 TPI Mild Cam
Transmission: 5-Speed T-5 WC
Oil Cooler
I got an oil cooler with my '87 350 block I picked up. After rebuilding it I went to prime the engine but oil came out of the oil cooler, it was my understanding that coolant was what ran through the cooler since it comes off the radiator.
My question is, did I install this incorrectly or if it is suppose to run oil to the radiator, does the radiator have separate cells for oil (i don't want my oil and coolant mixing of course) or does this one need to run to some separate heat exchanger? Thanks
Old Jul 18, 2014 | 05:16 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Oil Cooler
There shouldn't be oil coming out of the oil cooler hose fittings. Only coolant circulates through the cooler.
Old Jul 18, 2014 | 06:14 PM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
Re: Oil Cooler
You can only install those things one way. If oil is coming out of the hose fittings in the front, it is cracked and should not be used (unless you want you oil to be chocolate milk). If it is coming out over the top, bad gasket.
Old Jul 18, 2014 | 06:27 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: Oil Cooler
Is it a factory style Modine heat exchanger? Or an aftermarket oil cooler?
Read this...
The factory unit passed coolant to exchange heat (whether warming or cooling the oil). While an aftermarket unit, such as this one from Summit, redirects the oil to a mini-radiator unit to exchange heat with air.
Stock KC4
Aftermarket:
Old Jul 18, 2014 | 06:33 PM
Re: Oil Cooler
I had assumed it was stock but it looks a bit different from the ones shown in those pictures. Same basic design but the oil lines screwed into holes rather than a hose clamped on.
Old Jul 19, 2014 | 09:17 AM
Re: Oil Cooler
Yeah so its the aftermarket one I guess but its made by GM. Its part gm 14088854, looks like this.
http://ts1.mm.bing.net/th?&id=HN.607...d=1.9&rs=0&p=0
Looks like I will just have to get an adapter and have no oil cooler, thanks guys
Old Jul 19, 2014 | 09:48 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Oil Cooler
that style of cooler was used on cop cars and trucks with H/D cooling-I use that style on my Camaro with a separate oil cooler radiator(whole setup taken from '83 cop impala)You could use that oil cooler adaptor to install oil cooler later-though as made by GM,some of the oil passages can benefit from a little "porting"to reduce oil flow restrictions present in as-cast form
Old Jul 27, 2014 | 01:20 PM
robg91z's Avatar
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
Re: Oil Cooler
Sorry for the thread jack guys but how do you delete the oil cooling system? Mine is a 91 z28 just did a carb swap for racing thanks
Old Jul 28, 2014 | 07:48 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Re: Oil Cooler
Remove the adapter (between the block and filter).
Connect the two heater lines where you disconnect the hoses to the heat exchanger (at the passenger frame rail). Or, since you are racing, remove all heater hoses and plug the openings.
Old Jul 28, 2014 | 08:12 AM
robg91z's Avatar
Engine: 350ci TPI
Re: Oil Cooler
Is there a pic of someone that has done this? Just so i can get the idea . Thanks for the reply
tyeo098
Nov 30, 2015 06:27 PM
1992Z28!
Nov 19, 2015 07:33 AM
skinny z
Oct 5, 2015 06:23 PM
CatmanFS
Sep 19, 2015 09:00 AM
apie2546
Sep 5, 2015 07:40 PM
