Hypertech Cooling Fan Switch
Old Jul 21, 2014 | 07:45 PM
fireball451's Avatar
Car: 91 Z28, 91 Z28, 92 Z28
Engine: LB9, LB9, L98
Transmission: T5, T5, 700r4
Axle/Gears: 3:42, 3:42, 3:23
As I go to order another Hypertech fan switch (due to a slip while fooling with the headers and breaking the one I have), I discover that they show to be discontinued everywhere I look. I did manage to find one, but good freaking grief. This has been my switch of choice over the past 20 years. Now what?? What if I break another one? Or one quits working? Or I do the unheard of and buy another third gen??? ... Well not really unheard of at all...... Really aggravating trying to find parts and run into "DISCONTINUED"....
Old Jul 22, 2014 | 05:44 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Re: Hypertech Cooling Fan Switch
If it's a standard NTC (negative temperature coefficient) switch, just look one up with the same resistance specs in the niehoff or bosch catalog. As long as it fits in the passage without blocking it and reads the same resistance for any given temperature, you are set.
Old Jul 23, 2014 | 08:42 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I'd call them, I'm sure they have product that's not sold. They probably just don't sell enough of them to keep them in stock.
Old Jul 23, 2014 | 10:42 AM
parts man's Avatar
I was in the same boat called Hypertech yesterday and they said that they had stopped carrying them eight months ago. Some problem with fans staying on after reaching set temp. I wanted a 4028 and none left, I have a new 4026 in the box still if you are interested.
Old Jul 30, 2014 | 10:13 PM
Just found a suitable replacement at Summit.
Ron Francis AR33
176 on 161 off.
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
