A/C Compressor Replacement Tips?
Old Jul 31, 2014 | 02:32 PM
NinjaCameraman's Avatar
My '91 RS 305 (retrofitted to R-134 last year with Four Seasons parts) is currently parked awaiting repairs. The A/C compressor is knocking and probably a few minutes away from seizing entirely.
My shop of choice is quoting $600 to replace the compressor and "a couple of other parts."
I'm inclined to replace the part myself. Some quick online shopping shows I'd be looking at about $200 after shipping to grab a compressor, dryer/accumulator, and orifice tube.
Besides spending the next couple of weeks watching Youtube tutorials and looking through the Haynes manual for the car, are there any tips/tricks I should know about swapping out the compressor and these parts? Any pitfalls I might hit on doing this with a retrofitted system?
Old Jul 31, 2014 | 05:02 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: A/C Compressor Replacement Tips?
You're supposed to have the system emptied/filled by an a/c shop but other than that it's just removing and replacing stuff. Keep dirt and moisture out of the lines when you disconnect them. You may also need a couple of special tools to disconnect fittings.
Old Jul 31, 2014 | 05:39 PM
ssj2link's Avatar
Car: 2000 Trans am vert 87 GTA
Engine: 5.7/5.0
Transmission: T56/700R4
yeah and you are going to need to vac the system out when its all assembled. i just did a complete job on my truck over a year ago and i still have ice cold A/C. dont skip on the vacuum part! clean all the lines thoroughly and replace ALL seals, also do NOT overcharge the system
TheExaminer
Aug 25, 2015 07:34 PM
rh76camaro
Aug 15, 2015 12:48 PM
BikeFarm
Aug 11, 2015 11:35 PM
Thaney9
Aug 7, 2015 08:25 PM
