upgrade wiring for spal fans
Old Aug 12, 2014 | 06:04 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Is it possible for me to wire up my dual 11" spal fans into my factory wiring using my factory relays as well? The instructions say that they use a 30 amp fuse per motor. Is that too much for the factory wiring?
Old Aug 24, 2014 | 01:05 AM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Re: upgrade wiring for spal fans
I don't know why nobody has replied to this question but as I see it, you shouldn't have any problem using your stock cooling fan wiring to run the two Spal fans.
Old Aug 24, 2014 | 04:07 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
The only thing I see that would be a problem, (at least for me it would) is keeping the IMO very high stock on temperatures the fans have.
What is it, something like 225* and 235* ?
Old Aug 24, 2014 | 08:32 AM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Reading back at your sig., I don't know that I'd want those fans coming on either at such high temps with having a force inducted 383( I didn't realize that in my first response)....the intake charge and heat generated from that combustion is going to create a lot of heat. Are you going to switch to lower rated switches for the fans?
Old Aug 25, 2014 | 02:22 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Yeah, I have a 200 on 185 off fan switch in it. Thanks for the replies.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
jbd1969
Aug 17, 2015 07:06 PM
