Hot 355
Old Sep 1, 2014 | 09:37 PM
Bens car's Avatar
Hot 355
Are the cooling systems on these cars too small for a mildly built 355? This is an 85 that had a tpi 305 we didn't get the electic fan with the car but now have 2 14 inch fans on it and still can't go more than 5 miles without getting to 240 degrees
Old Sep 1, 2014 | 11:01 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
Re: Hot 355
if the fans aren't shrouded, they wont be very effective. Is it a carb or FI car? under or over advanced timing will cause overheating too, check your hoses and that your fans are coming on when the should. These cars from the factory had the fans wired to come on at 220ish....way too hot!
Old Sep 2, 2014 | 08:03 AM
Bens car's Avatar
Re: Hot 355
It's the tpi with 24 lbs injectors and a reprogrammed computer and cam to match , we will recheck the timing tonight, I'm not having much luck finding shrouded fans and also wondering about a radiator with more cores . The older pickups used to have a four core when running a big block , certainly there has to be something for these cars
Old Sep 2, 2014 | 08:20 AM
dixie wrecked's Avatar
Car: 91 ws6
Engine: Carb'd 334 stroker
You should be fine, I'm running a mild 355 with a stock rad and a single electric fan and I never get over 180.
If you're using the factory gauge, that could be the problem.
They can be horribly inaccurate. As in, hooked up aftermarket and factory gauge to the same sensor, aftermarket read 180, factory read 230-260.
Old Sep 3, 2014 | 08:08 AM
Bens car's Avatar
Re: Hot 355
so last night we checked the and its way off , checked the engine light codes and it said has a short in the cooling sensor wire so we're thinking its trying to retard the timing because it thinks its hot , i've got it advanced to make it run and that is actually making it hot! computers!!! We're running a mechanical guage for the temp cause the dash guage is peged out , is there a seperate circut for the guage and the computer reading or do they use the same one for the guage and the computer imput?
Old Sep 3, 2014 | 08:15 AM
Joe Tag's Avatar
Re: Hot 355
ECM gets it's reading from the sensor on the intake by the thermostat housing. The one on the drivers side head is just for the gauge. Probably melted the wire against the exhaust and is grounded.
Old Sep 3, 2014 | 08:32 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Hot 355
The stock cooling system can handle a 355 no problem.
Get a stock or taurus fan setup. Also make sure your air damn in in place
Old Sep 5, 2014 | 08:13 PM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Re: Hot 355
Agreed. The radiator should handle it but the stock fan(s) are junk IMO. A Tuarus fan is 3X the fan the stock one is in terms of air flow! I use a Volvo relay for mine like so:
Old Sep 5, 2014 | 09:44 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Hot 355
I have a 355 in my 84 with a single electric fan and except for when the AC is on, It stays cool just fine.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Thaney9
Oct 24, 2015 07:26 PM
darwinprice
17
Oct 11, 2015 11:51 PM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
