Is this the engine coolant sensor?
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Is this the engine coolant sensor?
No. Your photo shows the coolant temperature sender for the cooling fan.
The coolant temperature sender for the gauge is in the left (drivers side) head between cylinders #1 and #3.
Do you think we have enough info to decide that? Going to have to do some investigating. Easiest way to start is grounding the green wire and looking for the gauge to peg with ignition on.
Car: '87 IROC
Engine: LB9
eightsixseven
Dec 16, 2024 01:50 PM
