what is this?
Old Sep 9, 2014 | 04:32 PM
foxnotgrey's Avatar
Car: 88 Iroc Z
Engine: 350TPI
Transmission: 5spd manual
what is this?
i was trying to figure out some of the wiring to my fan in my 88 and found this, i unplugged it while it was running thinking it was for the fan and the car died, and after plugging it back in it will start and immediately die, i think this might be to the fuel pump but i dont know, anybody know?
Old Sep 9, 2014 | 04:34 PM
foxnotgrey's Avatar
Car: 88 Iroc Z
Engine: 350TPI
Re: what is this?
thats right up next to the fan coming from the wiring by the battery
Old Sep 10, 2014 | 01:28 AM
IROC-Turbo's Avatar
Re: what is this?
Isn't that an ECM fuse?
Old Sep 10, 2014 | 02:07 PM
foxnotgrey's Avatar
Car: 88 Iroc Z
Engine: 350TPI
Re: what is this?
it didnt seem like a fuse at all, but again i really dont know, thanks for responding though
Old Sep 10, 2014 | 02:11 PM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Its not a fuse, its a single wire connector. Typically used for EST bypass. You would disconnect it to set base timing.
In your case I do not think that connector is for the EST, but I would bet its some sort of power wire for something.
Old Sep 13, 2014 | 12:41 AM
IROC-Turbo's Avatar
Re: what is this?
I'm pretty sure it goes to the ecm.I've reset mine with it.
Had a brain fart calling it a fuse.
Setting the timing connector is back at the firewall.
Can't say for sure what all it disconnects.But i'm 98% sure(memory sucks these days) it goes to the ecm.But my wire is orange and it's an 88.
It goes to the battery correct?
I have a couple of harnesses laying in the building.I'll see if I can get to them and trace that wire for ya if noone gives you a positive.
Old Sep 13, 2014 | 11:20 AM
foxnotgrey's Avatar
Car: 88 Iroc Z
Engine: 350TPI
Re: what is this?
thanks, it makes sense that it goes to the ecm, and yeah it goes to the battery
