radiator fans
Old Sep 13, 2014 | 11:29 PM
Gritz-n-Gravy's Avatar
Car: 1987 trans am
Engine: 305ci v8
Transmission: t5
Axle/Gears: 10 bolt 3.56
radiator fans
i was wondering how do i change the temp my fans come on, i think they come on at 230 and i want them to come on at 200.
Old Sep 14, 2014 | 10:46 AM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Fan temp switch from auto parts store or hawks, etc..
There are a couple threads that list part numbers for specific temp switches.
Old Sep 14, 2014 | 11:09 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: radiator fans
I have a Jet Fan switch p/n 60600 (New $20.00) on 195 deg & 185 deg off for 3rd gen dual fan set up. Send p/m if interested
Old Sep 16, 2014 | 08:43 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: radiator fans
Your fan should be controlled by the ecm which grounds out the relay. You can simply add a switch or install an aftermarket fan controller. It might be better to have someone burn a new chip with some other modifications to it also.
Old Sep 16, 2014 | 11:13 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: radiator fans
An 87 TA could have either the LG4 or the TPI motor. LG4 would have been controlled by fan switch in the pass head.
Old Sep 16, 2014 | 10:10 PM
Car: 1987 trans am
Engine: 305ci v8
Transmission: t5
Re: radiator fans
i have the tpi motor
Old Sep 19, 2014 | 12:19 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: radiator fans
The thermostat temperature should also be changed when lowering the fan "on" temperature.
I use a 190* fan "on" switch with a 180* thermostat and they work very well together.
Old Sep 19, 2014 | 07:01 AM
naf's Avatar
naf
Re: radiator fans
and you can still control the fan 'on' temp with a switch in the cylinder head. just have to remove the plug that's there and screw it in. with the appropriate switch, of course.
Old Sep 19, 2014 | 09:00 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: radiator fans
sheachopper
Jul 31, 2019 11:27 AM
Fanatic1074
Oct 2, 2015 03:47 PM
