Digital A/C vacuum control issues (A/C stuck on defrost problem found)
Old Sep 25, 2014 | 08:51 PM
L98GTA87's Avatar
Car: 1987 Trans am
Engine: 350 Vortec Stealth Ram
Axle/Gears: 02 SS Torsen Zexel 3.42
Have a 87 GTA with the digitial dash. A/C vacuum is different from one with manual controls and has a different vacuum setup. This unit is mounted to the heater box on the passenger panel side under the dash panel where the ECM is.
Been chasing a A/C stuck on defrost and led me to this. Mounted in original position, i get the air only coming out of defrost vents. If I unmount it and let it hang, I will get air in the cabin all day no problem. But move it back up and back to defrost.
Can anybody tell me exactly what this part is, any steps I can take to remedy this problem? Would be greatly appreciated.
Old Oct 5, 2014 | 02:52 PM
sheikss's Avatar
Car: 88 Trans Am GTA
Axle/Gears: 12 bolt 3.73
Re: Digital A/C vacuum control issues (A/C stuck on defrost problem found)
Do you have a factory manual for the digital dash stuff? If so I could use info related to the blower motor. Motor works when I jump it.
Old Jan 18, 2015 | 07:58 PM
L98GTA87's Avatar
Car: 1987 Trans am
Anybody have this part they'd be willing to sell?
Old Jan 18, 2015 | 10:48 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
It's a vacuum module, they were used with the electrically controled heater systems in the digital Thirdgens. It accepts engine vacuum and then relays it to the various vacuum Solenoids to open/close the various heater box flaps.
Since it appears to work when hanging - but not work when installed,... is it possible that mounting it is causing a "crip" in the vacuum line that feeds the module ??
lakeffect2
Aug 23, 2015 08:44 AM
bjpotter
Aug 12, 2015 06:06 PM
BikeFarm
Aug 11, 2015 11:35 PM
antares57
Aug 6, 2015 07:47 AM
