Long or short Water pump
Car: 1988 IROC-Z Camaro
Engine: 383ci SBC
Axle/Gears: 2.77 9 bolt borg warner
1988 Iroc-z Camaro with the L98 TPI 350 and the factory A/C serpentine setup. went to get a new water pump and not sure if the serp are considered long or short or how to tell the difference between the two.
Re: Long or short Water pump
How to tell the difference:
Q: Is your car from 69 up? (or if it's a Vette, 74 or thereabouts up?)
A: You need a long water pump.
Meanwhile, ALL water pumps for the serpentine system (the "reverse rotation" ones) since they are 69-up, are "long". Since there is no such thing as a reverse rotation "short" pump (in stock trim, anyway; it would be possible to create one), it's a moot point though.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
is that one best left forgotten?
I'm sure you recall that the engine it was on was the smallest small block ever made: 262.5?
Engine: 383ci SBC
Thank you guys for your time. One would think that if it is so straight forward that the databases at anywhere from Napa to Summit would have that built in with their year/make search. Or maybe working as an analyst has me bitter to imperfect databases.
So Just for clarification I need a reverse rotation long neck water pump?
not being around my car for the next few months I'm having a hard time envisioning the front, is reverse counter clockwise rotation?
Any recommendations on something for a mild performance 383?
reverse rotation means it turns opposite the rotation of the crank pulley. older style v-belts wrapped around both so they turned in the same direction. Newer style, like yours, use a serpentine belt that is routed such that the water pump spins in the opposite direction of the crank pulley.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Street Lethal
Apr 30, 2019 12:14 PM
MoJoe
Sep 24, 2015 09:12 PM
Dialed_In
Aug 20, 2015 01:45 PM
