question on lower rad hose squeezed
Old Jan 8, 2015 | 09:06 PM
tb3's Avatar
tb3
Car: 1989 Firebird Base
Engine: 2.8 V6
Axle/Gears: stock
I i just installed a 36mm front sway bar. I also installed the TDS wonder bar, and when I got it mounted, it puts a pretty good squeeze on the lower radiator hose. I have a 89 2.8 which has a differant radiator than the v8's.
It doesn't squeeze it over half, less than a 1/4.
Do I have any reason to be concerned?
pic attached to show the area of concern.
Attached Thumbnails question on lower rad hose squeezed-20150108_165324_resized.jpg   question on lower rad hose squeezed-20150108_174208_resized.jpg
Old Jan 9, 2015 | 02:54 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: question on lower rad hose squeezed
The poll does not look like it would cut into the hose but that point on the mount would bother me.
I believe I would consider runing a shorter hose or cut the one I have to pull it away a little.
It looks like there's enough play with the hose you have.
Old Jan 9, 2015 | 07:39 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
And get one of those corrugated hose protectors and slip over the hose for extra protection.
If you leave it as it is, it's just a matter of time before it wears through.
Old Jan 15, 2015 | 11:41 PM
tb3's Avatar
tb3
Engine: 2.8 V6
Axle/Gears: stock
thanks guys!
because of the way that hose is shaped, I can't really shorten it. I will probably see if I can get a universal type hose to fit, or convert to the v8 radiator
1992 Trans Am
May 10, 2023 07:19 PM
91 rally sport
22
Apr 5, 2016 05:06 PM
1985chevydude
Aug 20, 2015 12:29 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
