weird fan
Old Jan 25, 2015 | 12:00 PM
IlikeIroc's Avatar
Car: Iroc z28
Engine: lq4
Transmission: 4l80e
weird fan
Greetings from Estonia.
Hi there. I have got 89 iroc Lo3 tbi and the fan behaves bit weird.. what it dose is when you start up the car it doesn't work, like normal (temp. low) and when you start to drive it comes on and stays on(when its cold). What im doing is shutting the engine off and turning ignition key on and waiting when the fan decide to stop. After that works well, engine warms up comes on like it should and go's off.
Relay? Fan sensor?
Old Jan 25, 2015 | 12:18 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Re: weird fan
Sounds like a shakey fan switch/sensor.
Old Feb 18, 2015 | 09:56 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: weird fan
Relay? Fan sensor?
Welcome to TGO!!
Single fan?
The fan will not turn on until the car reaches operating temperature. Factory setting is 220*F or so (about 104*C). the fan will cycle on and off with the temperature of the car to keep it around 220*.
Does the fan turn on when you engage the AC?
There is a fan switch on the passenger head, just forward of the dipstick. This is the switch that runs the fan. Make sure the wire going to it is in good shape.
Find your fan relay, mine is on the firewall, not sure about the Camaro's. Make sure all the connections are seated properly on it. Mine worked loose causing an intermittant fan issue. I went through four relays before I found it.
I hope this helps. Please let us know if you are still having issues.
Old Mar 8, 2015 | 04:19 PM
IlikeIroc's Avatar
Car: Iroc z28
Engine: lq4
Transmission: 4l80e
Re: weird fan
I found the relay and found the wire what goes to the fan switch. And i located
the wire what comes from the fan switch to relay..and wired up directly. Opened the relay and seems to be fine.. and still... unbelievable still dose it. Sometimes works fine and sometimes comes on and stays on. Fan switch is replaced(brand-new)
Removed the AC radiator, hoses bla bla ,in principle everything only under the hood.
and Yes it did start the fan when you put on the ac in the car. But now it dosent come on because i wired up relay directly with fan switch.
please.. I just want to save fuel and most of all save the engine
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
