Help restoring factory fan function
Old Apr 21, 2015 | 09:40 PM
Mason_99's Avatar
Car: 1985 Camaro IROC-Z
Engine: LB9
Axle/Gears: 10 Bolt, 3.42 gears
I've got an '87 IROC-Z TPI 350 car I acquired last year. One thing I want to fix on it is to remove the manual fan switch and getting the cooling fans working the way they did from the factory. The car also has the A/C removed and I plan on leaving that off. So far I have found that the plugs behind the battery unhooked that I assume go to the cooling fan relays that are also missing. Are both relays cooling fan relays or is one to the A/C?
I'm hoping that the factory wiring hasn't been hacked into. I plan on replacing the coolant temp switch, relays, and check the wiring. Can anybody else give me any advice that may help me out?
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
