Easy question - temp gun
Old Apr 26, 2015 | 08:12 PM
89 formula TPI's Avatar
Engine: LB9 5.0L TPI
Axle/Gears: 9-bolt Borg Warner, 3.45
I don't think my temp gauge is accurate. I have a heat temperature gun. where should I point it to get an accurate temperature reading?
Old Apr 26, 2015 | 09:00 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
Re: Easy question - temp gun
You can only get an approximate temp reading. Temperature sensor is inside the coolant system.
Old Apr 26, 2015 | 10:00 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I check the thermostat housing and the start of the upper hose from there and the temperature sender and area around the temperature sender its self and use the hottest temperature I get.
Old Apr 27, 2015 | 02:45 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
yeah i use the thermostat housing
Old Apr 27, 2015 | 09:29 PM
cool, tks guys!
just want to get a sense of if my fans are not turning on at the right temp
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Irocohio
Aug 12, 2015 08:03 AM
