Heater Core Replacement (Post Cover Removal)
Old May 10, 2015 | 09:13 PM
Firm's Avatar
Car: 84 Camaro 2.8L, 85 T/A 305 LG4
I've been reading all the heater core replacement threads, almost all of them debate what's needed to remove the plastic cover, but in my car it looks really easy for me to remove the plastic cover (I have really skinny arms). But what I am struggling to understand is what I need to do after removing the cover? I assume there's a bracket or something holding the core? Are the bolts holding it in place obvious, or are they hidden?
Any other tips? I am planning to tackle it next weekend...Damn thing just started leaking last night, luckily I don't need the car this week.
Old May 10, 2015 | 09:16 PM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
Re: Heater Core Replacement (Post Cover Removal)
If I remember correctly there are no bolts holding it in, just the hoses. If there are bolts then they must be easy to get to, since I don't remember having any trouble getting it out when I had the HVAC apart.
Old May 10, 2015 | 11:43 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Recently replaced the cores in both my Formula and '88. After removing the cover there is a plastic bracket that the core is attached to. There are 4, 7mm I think, screws holding the bracket in place, then there are two metal braces, again 7mm screws I think, holding the core to the bracket. The hardest part I had was trying to get the new core outlets to go through the firewall. Good luck.
Old May 11, 2015 | 12:20 AM
someone972's Avatar
Engine: 5.7L TPI
It's been a while so he's probably right. The hard part is getting everything off down to where the heater core is. After that it's a breeze.
Old May 11, 2015 | 06:44 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
The heater core cover in a A/C equipped car is easy to get to and remove
without having to disassemble the dashboard.
Its just a couple of the screws on the cover are a PIA to get to but not
impossible..................
Casey Meyers
Mar 2, 2016 10:46 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
3rdgenparts
Aug 8, 2015 07:09 PM
