91 Formula center airdam section interchangeable with camaro?
Old May 22, 2015 | 11:25 AM
michael's Avatar
Car: 1991 Formula
Engine: 6.2 383 TPIS Miniram
Axle/Gears: Moser 9" 4.11
The formula my fiance and I picked up has two cutouts in the center section of the airdam for previously installed fog lights. Is the center section interchangeable with any other cars (82-90 FB) or even camaros?
The current setup is the 3 piece so I'm assuming I'm stuck with the center section from a 91-92?
I'm thinking about taking one from a camaro and cutting out the size I need to patch the holes in the current one that is on the car. Then using some plastic patch stuff to make it all uniform. Should be a whole lot cheaper then purchasing the center airdam piece for a 91-92.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
sonu1975
Aug 11, 2015 08:38 AM
87350gtanj
Aug 8, 2015 10:32 AM
