Replacing the lowside pressure switch
Car: 89 Camaro RS
Engine: 5.0L 305
Ok A/C use to kick *** but all of a sudden my compressor is running erratically or should I say not running. When I first start turn on the a/c, a/c clutch engages for maybe 3 secs, shut off, does it one more time, that's it. Maybe a couple of really short engages like a half second but never starts back up. Lowside will get down to 50 psi and shut off. The really short engages is making me lean towards a bad low side pressure switch, possibly bad High side. How do I remove these switches and do I need to evacuate the system before replacing, thanks.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Replacing the lowside pressure switch
Sounds like your just Low on Freon.
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Once you have that off, unscrew the low pressure cycle switch. You'll probably need an open end wrench to loosen it.
No need to evacuate the system. There is a schrader valve behind the low pressure switch. So when you remove it, it may go "pfffft" for a split second. But will stop very quickly too.....Install is the reverse. Don't overtighten the low pressure switch. The part that screws onto the accumulator will crack if overtightened.
Car: 1982 Z28
Engine: 5.0L
Axle/Gears: Ten Bolt Disc Posi 3.23
Sounds like your a can low. If your running R12 this might be the time to upgrade to R134a or R152a. If your already running 134 just put in a can until you see moisture condense on the accumulator. Since your switches are 25+ years old you might want to replace them. Follow Reid's advice. If you still have R12 and don't have your own supply it will be $$$ at a shop that still caries it.
Car: 88 Camaro
Engine: L98 350
Might try wiggling all the connectors on the system. Mine loses connection at the high pressure cut out on the back of the compressor. Works for a while then quits, usually on the highway. I put a jumper on it for now. Usually short cycling points to low refrigerant, but the LS pressure should show this.
TA8487
Aug 16, 2015 12:21 PM
