A/C cold then Warm
Old Jun 25, 2015 | 04:27 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
A/C cold then Warm
A/C stopped working, so I had it refilled with R134 and it started cooling. However, it will blow cold air (48 deg) then after ten minutes or so it will blow warm air about (70/75 deg) then repeat this cycle or close to it. What gives??????
Old Jun 25, 2015 | 04:42 PM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Re: A/C cold then Warm
It sounds as though you have a system restriction-typically the orifice tube can collect debris and in short order it can become so clogged that little to no flow is occurring. This is why AC gauges are vital to determining what's going on. If you hook gauges to your system, assuming the system is properly charged, if the AC goes from cold to warm/hot and the high side system pressure goes way up while the low side slowly creeps up, that's an indication of a system blockage.
Was the AC system opened at any time prior to you putting freon in it? If so, did you pull a vacuum before charging?
Old Jun 25, 2015 | 07:01 PM
DJP87Z28's Avatar
No, the system was not opened up before the R134 was changed. Will be taking the car this Monday and wanted to get a idea what might be happening, Thanks for the info.
Old Jun 28, 2015 | 11:29 AM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Is the compressor cycling off and staying off when it blows warm like this? Sounds like the low pressure cycle switch needs replacing. A cheap fix easy. You can do it in your driveway.
https://www.thirdgen.org/forums/cool...re-switch.html
Old Jul 13, 2015 | 03:53 PM
DJP87Z28's Avatar
Update on my A/C problem.....Replaced fan motor and two leaking fittings and now the system works. No more warm air, it is now 40deg coming from the center vent.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
jrdturbo
Mar 31, 2016 02:58 PM
blackz281le
Jan 11, 2016 07:51 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
