Need some fan help.
Old Jul 10, 2015 | 09:35 AM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
Need some fan help.
What's up guys I'm having a weird problem with my fans. This morning I went to start the car and the battery was dead I accidently left the ignition in the on position. I charged the battery and the car started right up. I noticed my gauges where not working, the fuse was bad changed it everything worked. I went to start the car and with the key on my fans come on? It never use to do that usually they would turn on when it hit operating temp. I changed a 5 pin relay that was on the driver side fire wall. But still nothing. Any help would be great thanks.
Old Jul 10, 2015 | 10:16 AM
Engine: 350 tpi
Re: Need some fan help.
Found out If I dis connect a black with purple wire from the relay I replaced the fans will turn off
Old Jul 10, 2015 | 12:56 PM
Engine: 350 tpi
Is there another relay after that that maybe could be stuck open somewhere?
Old Jul 10, 2015 | 03:24 PM
Engine: 350 tpi
From what I've been reading the po installed a relay to control the fans. On the driver side firewall there is a 30 amp relay with 4 connectors. 1 is ground another is a black and purple wire. 1 is orange and another a thin grey one it looks like. When I dis connect the black and purple one the fans stop turning on. When it's connected they kick on when the key is turned on without starting the car.
Old Jul 10, 2015 | 08:32 PM
Engine: 350 tpi
I went to mess arou.d with the car starts up but now the fans do not kick on at all. And the car runs terrible it can barely stay idling. Any help guys I'm really frustrated with this car already. Yesterday everything was working perfect.
Old Jul 11, 2015 | 12:48 PM
Engine: 350 tpi
I figured out 2 of my spark plug wires where off so I connected them and it runs fine now. Still can't get the fans to kick on. I replaced the 30 amp relay already. The only way I get them to kick on is if I put a jumper from the 12 v to the black and purple wire going to the fans. Both kick on.
Old Jul 13, 2015 | 05:10 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fantastic Fan Plan
No telling how much the PO messed with the fan wiring so you probably need to visually trace wires to make sure he didn’t make connections where none belong.
Originally Posted by Al Nonymous
I changed a 5 pin relay that was on the left side fire wall. But still nothing.
Did you remove the relay with fan running to verify it was the Fan Relay?
If yes, use a voltmeter or test light
(the type for testing for voltage, not a continuity tester) to see if there is power on the orange wire at the fan relay.
The car can be totally off when you are testing for that voltage.
Is there power there?
Happy Racing !
“Professional Maniac Operating, Do Not Drive 330 MPH In Your Own Home”
Old Jul 13, 2015 | 05:59 PM
Engine: 350 tpi
Re: Fantastic Fan Plan
Well I've run a switch for a temp fix. But I want to get it going. The 4 wires a traced where. My 12v ignition coming from the fan fuse. My ground. A black with purple going into the fans. And an all orange one I don't know where this one goes.
Old Jul 13, 2015 | 06:32 PM
Engine: 350 tpi
The black and purple is jumped to the other fan wire on the passanger side too. So those where all the wires o traced going into the relay. The ac switch on the passenger side head is cancelled so I'm going to check the one on the driver side head. How can i check this switch?
Old Apr 1, 2016 | 07:12 PM
Engine: 350 tpi
Bump. I'm trying to get the fans to kick on by temperature again. Any help? Right now I'm running a switch but want to cancel it
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
Numbah-1
Oct 2, 2015 08:27 AM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
