89 GTA Trans Am not getting any heat.
Old Sep 18, 2015 | 12:48 PM
bryan623's Avatar
Car: 89 GTA
Engine: 5.7 TPI
Hey guys eariler this year my heat stopped blowing hot air and now its just cold. The car doesn't overheat, and I don't see it losing any antifreeze so what could be my problem? Could the heatercore be clogged? I have noticed a lot of gunk in the radiator. Should I try to flush the system and hope to its just clogged?
Old Sep 18, 2015 | 06:42 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: 89 GTA Trans Am not getting any heat.
Check your heater control valve. Make sure the vacume line is connected. If it is then I bet the valve is stuck closed go to the parts store and purchase a new one
Old Sep 19, 2015 | 12:22 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Lots of possibilities:
Clogged heater core.
Air lock (Heater core is high).
Pinched heater hose.
Water valve.
Thermostat.
Blend door or cable problem.
Old Sep 19, 2015 | 10:13 AM
ex-x-fire's Avatar
Does the temp gauge run close to the middle while going down the road?
Both heater hoses should be hot, if only one is hot the there is a restriction somewhere.
LilHot
South Central
Apr 13, 2026 11:46 PM
The_Phoenix
Feb 4, 2016 07:10 AM
armybyrd
Dec 5, 2015 09:22 AM
stalkier
Aug 21, 2015 01:54 AM
gta power
Aug 13, 2015 06:15 AM
