Fastest Drying (Fully Cured) Automotive Silicone
I can't seem to find any automotive silicone suitable for oil/water resistance that "fully cures" in less than 24 hours...
It seems ridiculous that in this day an age you can't easily find such a thing.
IS there such a animal?
thanks in advance.
thanks in advance.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Silly Subject
If you have a heat gun try R32-2186 from NuSil.
It’s a 2-part silicone.
Mix it.
Heat it.
Race.
Happy Racing !
Even Tho I Might Destroy The Car During The Race, At Least It Looks Gorgeous At The Start
Mix it.
Heat it.
Race.
Happy Racing !
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Fastest Drying (Fully Cured) Automotive Silicone
i have found over the years, silicone to be a poor choice anywhere on an engine . if i need a gasket sealant . i use permatex #2 exclusively
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
1. Permatex makes an anaerobic gasket maker that might work for you.
2. Their Right Stuff gray can be put into service immediately after assembly. This is similar to the stuff you use to seal motorcycle engine case halves.
http://www.permatex.com/
Car: 1983 Z28
Engine: 385 Fastburn
Yeah, I'm actually hearing more and more that using silicone to hold gaskets in place/in place of gaskets on engines is a no-no, as chunks can be squeezed out and end up in your engine somewhere.
Granted, I'm guilty of having done this on numerous water pumps, etc, but not anymore.
