Heavy duty vs. high volume water pumps, what's the deal?
Car: 92 Camaro
Axle/Gears: stock
Are they the same? I haven't found anything to tell me what makes them different of even how much water they flow. My assumption is the impeller is different, maybe the pitch of it, like a propeller, but no where have I seen anything on this. I want to buy a high volume one.
Car: 1988 GTA
Engine: VIN F 305 TPI
Transmission: AUto
Re: Heavy duty vs. high volume water pumps, what's the deal?
Heavy duty should have bigger bearings, while high volume should have a bigger internal cavity and impeller for more flow. Since the drive pulley is an overhung load, better bearings might be a good choice, and flow is modulated by the thermostat so unless there is a reason, greater than design flow is probably not needed. That said, unless you have some way to compare the original design and the heavy duty, these names are probably just advertising.
Car: 92 Camaro
Axle/Gears: stock
I wish there was a way to know. So I guess heavy duty doesn't flow more just built more rugged?
Axle/Gears: 10 Bolt 2.73 Open
That would be the implication.
If you have some particular units in mind, post up some links.
Engine: LB9 5.0L TPI
Axle/Gears: 9-bolt Borg Warner, 3.45
I replaced mine over the summer and had the same question. I put them side by side and didn't see a difference in the impeller. The price difference was only 10 bux more so I opted for the "high flow" model though I don't think there is a differenice unless it's in the internal cavity as the person above me mentioned
Orr89RocZ
23
Jun 2, 2016 12:39 PM
