anyone running distilled water and Redline Water Wetter
Old Mar 22, 2016 | 08:33 AM
BOTTLEDZ28's Avatar
Transmission: A4
I'm in the middle of doing a complete fluids change in my car and was debating on using the green stuff, the orange stuff or going with distilled water and a couple bottles of Redline Water Wetter.
This is a garage kept spring/summer/fall car. No winter driving at all and it will not be in any temps under 50 degrees.
Car has 58K miles on it and would like a coolant that will give me a few more miles out of the engine than regular green stuff.
Old Mar 22, 2016 | 08:56 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: anyone running distilled water and Redline Water Wetter
Considered there are multiple 200k+ mile 350's out there, I wouldn't worry too much about the coolant. I run green coolant with the stock cooling system without any issues.
Old Mar 22, 2016 | 12:39 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
I don't think putting in a different type of coolant really would matter long term, at least, measurably.
You can get a lower temp t-stat and have the chip burned to kick the fan on sooner if you are wanting to lower temps consistently.
Old Mar 22, 2016 | 12:49 PM
-srs-'s Avatar
Car: 1991 Z28 Vert
I run that combo in my 40k mi vert. It definitely runs cooler but I can't say for certain if it was the mix or the fact that the flush that I did was probably its first flush EVER.
Old Mar 22, 2016 | 09:35 PM
bop11's Avatar
Car: 1988 GTA
Engine: VIN F 305 TPI
Transmission: AUto
The coolants have additives for rust prevention and pump lubrication. I would resit running anything but one of the better brand anti-freeze even if the car never sees cold weather.
Old Mar 22, 2016 | 09:41 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Green stuff works fine if you flush it every couple years.
Old Mar 22, 2016 | 10:26 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
X2 unless u see track use. They dont like coolant in cars. I ran water and water wetter just fine. Didnt see any difference in cooling in my turbo motor vs 50:50 antifreeze.
Old Mar 23, 2016 | 12:42 PM
BOTTLEDZ28's Avatar
Transmission: A4
Thanks guys. I will just drain as much of the original 58K miles coolant as possible and refill with the same green stuff mixed with distilled water.
Old Mar 26, 2016 | 06:56 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Didn't DexCool come out as a replacement for the old green stuff? I thought the DexCool was better with aluminum?
EDIT: Did some research and found that DexCool probably is better with Aluminum but it has a disadvantage:
"Dexcool turns into a very strong acid when its heated and mixed with air.....so a open recovery tank is asking for trouble. So is running the rad low on coolant. If its a pressurized closed tank your ok with dexcool."
This was pretty informative too:http://ls1tech.com/forums/general-ma...l#post12843293
Old Apr 1, 2016 | 12:54 PM
DonW's Avatar
Car: 1983 Z28
Engine: Carbed 305
This was the problem with vortec motors blowing intake gaskets all the time IMHO. Everyone was blaming the two piece plastic intakes back then, but when I took my truck in for its second intake job, the guy looked at me and said "look, its not factory, and its not recommended, but if you want to fix this thing let me lower your thermostat to 180, and change the dexcool over to green" He was right too. I have since retired that truck but I still have it. She has 360,000 miles and I use it hauling and for mulch every year now. It runs cool and I put 200K on it with his coolant swap with no more troubles. I swear it gets better gas mileage running cooler too, but I never calculated.
dusterbd
Mar 10, 2016 11:29 PM
b2tw45p
Mar 10, 2016 01:57 PM
Street Lethal
Mar 9, 2016 09:35 PM
Drone358
Mar 3, 2016 07:32 AM
edixon24
Feb 28, 2016 07:16 PM
