Need some AC help
Old Apr 18, 2016 | 08:37 PM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
Need some AC help
Ok it's a 86 Camaro. I replaced all the lines, evaporater, condenser, Accumulater and the compressor from a 87. It has 4th gen fans on it. So I charged the system to proper specs all preasures were perfect and it was working like it should but the air was not near as cold as I thought it should be. I have been reading that I should have put a blue orifice tube in it since it's 134A instead of 12 but I didn't know that and the one I bought from the parts store was white. Since I have to take it apart to change orifice tubes is there anything else I should do?
Old Apr 18, 2016 | 08:39 PM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
Re: Need some AC help
I forgot to mention the accumulator, evaporater and orifice tube are new.
Old Apr 19, 2016 | 09:00 AM
bop11's Avatar
Car: 1988 GTA
Engine: VIN F 305 TPI
Transmission: AUto
Did you replace the heater diverter valve in the cooling line under the hood? The heater is always on and the diverter makes it a little less on when the AC is on. The cooling control moves some vanes around to let less air flow through the heater core for more cooling. Possibly, your vacuum is not working or some of the vacuum motors are not moving the vanes in the air flow system.
Old Apr 19, 2016 | 09:05 AM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
My 86 didn't have that inverter on it when I got the car. That is something I will have to look into! I appreciate it.
I watched all the doors and they were closing good. Like from cold to hot. Or defrost to vents and so on.
Just out of curiosity what makes the inverter move? Is it suppose to hook to you're hot and cold door or what?
Old Apr 20, 2016 | 08:27 AM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
Anyone? I need all the info I can get?
Old Apr 21, 2016 | 02:15 PM
87gtaredonred's Avatar
when u say not as cold as it should be, what was the temp and was that with the car sitting still? My experience is that converted third gens to 134a work just ok not great lol. If your getting below 60 sitting still that's probably about right. Mine blows pretty cold when moving or going down the highway but sitting still it struggles. I did use the blue ford tube. I think it helps just alittle but still that's not sitting in traffic. I just changed my temp switch to come on so my second fan cuts on at 195 that also helped alittle. I think yours being an 86 only had a single fan setup. There just isn't enough air flow with these cars
Old Apr 21, 2016 | 02:19 PM
the diverter is vac. controlled, its on the passenger side inline with the heater hose, google thidgen diverter valve plenty of pics will show up
Old Apr 21, 2016 | 03:20 PM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
The diverter is on 87 and up not 86.
It was sitting still and the outside temp was 81 degrees and the air coming out of the vents was 59. And I put the system on a vacuum for 3 hours so I know that was good. And I feeled to specs. I used a white orifice tube since that is what auto zone pulled up. I should have checked that I guess. You are right the 86 was a 1 fan but I put a different motor in it and 4th gen fans. And I have them wired up to cut both fans on when the AC is turned on. I don't think the fans are the problem. But maybe it's still not enough. I'm pulling the orifice tube out. And have 3 options should I use the Red orifice tube or blue? If blue what car do I look that up under? Or should I use a adjustable orifice tube?
Old Apr 21, 2016 | 04:08 PM
honestly that sounds about right sitting on a hot engine ac running could be alittle lower, but the tube out of like a 95 tbird will work just fine, the red is for hotter conditions I believe I have never used it, never heard of a adjustable one hmmm, I think once you do that and check it while moving it will be a lot better
89irocz355
Mar 28, 2018 08:24 PM
89irocz355
26
Sep 12, 2016 01:28 PM
dreynolds
Apr 23, 2016 10:05 AM
89irocz355
Exterior Parts for Sale
18
Apr 11, 2016 10:17 PM
89irocz355
Mar 27, 2016 09:52 AM
