OEM RADIATOR 350 TPI 1987
Old Jul 4, 2016 | 03:10 PM
geoffhughes1986's Avatar
Hello,
I need to replace my existing radiator as it is leaking. I want a genuine ACDELCO replacement. The current radiator has this number
The problem is that when creating online orders the ACDELCO 21466 radiator does not seem to be compatible with a 1987 iroc-z 305/350?? 1988 onwards is! Any ideas?
Old Jan 25, 2017 | 08:11 AM
little foot's Avatar
Car: 1987 IROC
Axle/Gears: Borge Warner
Re: OEM RADIATOR 350 TPI 1987
Can anyone comment on this? I am shopping for the exact radiator and want a factory A C Delco. Why won't a 21466 fit my 87 IROC?
Old Jan 25, 2017 | 08:13 AM
Car: 1987 IROC
Can anyone comment on this. I want a new A C Delco radiator for my 87 IROC. Why won't a 21466 work?
Old Jan 25, 2017 | 09:36 AM
Drew's Avatar
AC Delco isn't always factory. At this point, an AC Delco radiator isn't going to be any closer to the original radiator than most other replacements. Chances are above average that it's the exact same radiator as several other brand labels, only difference being the name on the box.
Old Jan 25, 2017 | 10:09 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
http://parts-catalog.acdelco.com/cat...&parttype=2172
Old Jan 25, 2017 | 10:20 AM
Car: 1987 IROC
I agree with all you said, I guess I will hit up O Reilly's and see what they have. Thanks for your response.
Old Jan 25, 2017 | 10:23 AM
Car: 1987 IROC
I went to Amazon and they have a 21466 A C Delco in stock, but when I enter my vehicle info it say " does not fit your car" So I balked at the 21466.
Old Jan 25, 2017 | 03:05 PM
Drew's Avatar
Rock Auto lists the 21466 under 1987 also. Not sure why Amazon has the wrong data.
Old Jan 25, 2017 | 04:07 PM
Hey. I can confirm the genuine 21466 radiator I ordered and it fits my 1987 IROC fine. It comes with a coolant level sensor fitted which my car does not have a wire, but apart from that it's exactly the same.
PS it's for an Auto trans as it has an integrated oil cooler.
Old Jan 25, 2017 | 05:39 PM
Car: 1987 IROC
hat is good to know, I will check out Rock Auto.
Old Apr 18, 2018 | 03:57 PM
J.C. Denton's Avatar
Car: 85 Iron Duke, 88 GTA and 92 TA
Hi guys, may I chime in?
I need a new radiator, my original rad has the label "AF 52455839" on it. This number is the AC Delco 21466 nowadays. On the pictures at RockAuto the radiator seems to have separate oil cooler fittings on the right and on the left side and no drain plug. Do the fittings fit the original oil cooler lines? Is there a drain plug? Anyone has this rad and can give me some info? Or should I buy the Spectra Premium CU750? From the pics, this looks right for my car.
92 305 TPI
Thanks,
Oli
Old Apr 19, 2018 | 12:50 AM
Drew's Avatar
I don't think I'd put any faith into the AC Delco 21466. Simply because it doesn't look like any thirdgen radiator I've ever seen. Every so often there's an error in Rock Auto's listings. I sure wouldn't pay twice as much for a radiator that doesn't even look correct, just because it's an AC Delco. It's not like you're getting an actual GM Harrison radiator even out of the AC Delco box.
I'd go with one of the ones that looks like the original in your car. Chances are all the brands available are coming out of a few different factories at most. Probably can't go wrong.
Old Apr 19, 2018 | 01:36 AM
92 305 TPI
Thanks,
Oli
Oli, The photo on rockauto is wrong. My delivered 21466 AC Delco was the same as all the other photos on there.
https://www.rockauto.com/en/catalog/...,radiator,2172
Old Apr 19, 2018 | 01:40 AM
If you don't believe me, I had EXACTLY the same worry....
Old Apr 19, 2018 | 11:28 AM
Thank you for all the info! So I guess I will go with the Delco unit. Never had issues with ACDelco parts, 98% of the time I order everything from Delco if possible. Bought a Spectra Premium A/C Condenser last year from RockAuto because Delco units are no longer available and was not very happy with it. Fitted not very well, had to push and twist to get it seated behind my radiator, also the hard line fittings are very flimsy and a bit too long for the hard line to the orifice. Overall a typical China prduct, but it was the only one available, so I had to go with it. ACDelco OE parts were always the best choice for me so I think the radiator from Delco will be the best option.
Yes, I am a german guy and all germans are quality freaks, I know...
Old Apr 19, 2018 | 11:43 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
A lot, if not most, of the AC Delco parts are made in China now, and the "replacement" brands are coming from the same factory as the Delco parts. It's very difficult to get actual OE parts from the Delco brand now, some of the parts don't even come from Delco anymore. I actually prefer some of the other brands over them because they were the OE, like Delphi/Aptiv
cougar68
Mar 27, 2017 01:11 PM
TLynch911
Jun 27, 2016 06:52 AM
85@IRocZ
21
May 17, 2016 08:03 PM
white88TA
May 4, 2016 02:21 PM
section 8
Apr 14, 2016 03:45 PM
