Is this a Camaro or a Firebird? And can you tell us what year this is? It may not make any difference, but is the car an automatic or manual trans? The more information you give, the better it is for us to narrow it down.
It's a 1988 camaro with a 355 carb ,iam re-installing the a.c. system and I am trying to figure out the wiring harness, and there a plug that goes to this and I don't know what it is or doe
that is the MAP sensor-tells the ECM how much vacume the engine is pulling.MAP sensor location varies with different years and engines,'84 up carbed v8s have a same appearance BARO sensor in that location.
On yet another one of GM's stamped steel brackets fastened with a regular sheet metal screw. In some ways GM made these engines bays look so cheap and thrown together.
these cars were cheaply built and thrown together..
