R-134a conversion questions
Old Aug 15, 2016 | 04:50 PM
Hawkeye1980's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
Hey gang
My 89 has not had a/c for MANY years. I bought a new condenser for it recently and going to replace. I also got a full a/c test kit with vacuum pump and gauges so I can vacate the moister. Here are some questions I have.
1. I have the conversion kit with the new ports ready to go just so all are aware
2. The car called for 36 ounces in r-12, I understand there is a formula to convert to R134a and it comes out to 27.5 ounces right?
3. What oil do I use, factory says mineral oil but it does not mix with R134, so should I fill it with PAG 150? (this once I confirm no leaks and all moister is gone)
4. the car call for 8 ounces of oil, so should I poor a full 8 ounce bottler in the feeder tube before I fill the R134?
Thanks in advance, any additional info is appreciated as always.
PS, I should really ask what viscosity of PAG should I use instead of Mineral oil? Or something different from PAG and Mineral all together?
Old Aug 15, 2016 | 06:49 PM
Engine: 5.7
Axle/Gears: Stock
Re: R-134a conversion questions
Got most questions answered in this post:
https://www.thirdgen.org/forums/cool...ml#post6069113
I am good.
Bowtieman1970
Aug 17, 2016 02:50 AM
Loudnproud86
May 26, 2016 05:20 PM
Bryanm254
Mid-West Region
Apr 1, 2016 12:31 PM
Steve
Southern California Area
Mar 28, 2016 10:09 PM
Scorched1984
Mar 13, 2016 10:10 AM
