Radiator Support
Old Aug 23, 2016 | 10:46 AM
Nick71411's Avatar
Radiator Support
Can somebody please post a picture of what support is needed for a 3 core radiator in my 88 IROC Z. I've tried finding it online but I keep getting 2 different pictures.
Old Aug 26, 2016 | 01:01 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Radiator Support
There was only one radiator cover that come with these cars, its the same one on the 4 cylinder car as the highest performance 1LE 350 cars. When members go with thicker radiators we usually end up making one from metal. Mine is/was an Aluminum channel that I cut the back off and tig welded it at the correct angle, guys like Twin_Turbo have some type of steel bent in a metal brake. Another member on here simply made an extension piece that was an inch long that screwed to the four front bolts on the core support that allowed the cover to sit back a little more.
Old Aug 26, 2016 | 03:29 PM
Twin_Turbo's Avatar
Mine are all cnc punched aluminum. The cad templete is on this forum somewhere. I posted it.
Old Aug 27, 2016 | 12:20 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
You can also trim the rubber isolators (4) to about 1/8 thick.If you have AC there is another rubber piece between the rad/cond, those (2) can also be trimmed down.This alone was enough for my 3 core to fit.
darrellchevelle
Dec 29, 2016 12:04 AM
Streetstuff
Jul 6, 2016 02:29 PM
1 DwnCam
Feb 17, 2007 03:46 PM
RCAR7395
25
Nov 2, 2006 03:48 PM
Cruzin Kaz
Aug 29, 2003 04:08 PM
