RADIATOR MOUNTING PAD. Where can I find?
Old Feb 5, 2007 | 09:15 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Where can I find a OEM radiator mounting pad? Does the 3rd gen have upper and lower like the 4th gen? I don't think the local parts store is going stock something like this.
Old Feb 5, 2007 | 09:57 PM
Stevo's Avatar
Car: Pair of 92 Z28s
yes if i remember correctly there are top and bottom. Junkyard is your best bet.
Old Feb 6, 2007 | 03:09 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Would the 93 and up pads work?
Old Feb 6, 2007 | 10:41 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
they have them top and bottom, but i don't know if 93 and up will work.
Do what Stevo said a J/Y is prob an easy bet but it wouldent be hard to make something up would it?
This is what they look like:
https://ssl.shoalhaven.net.au/usgmse...145599bec6a431
Old Feb 16, 2007 | 06:29 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Called the local GM parts dealer. The lower pad has been dis-continued. The upper's are a stocking item.
Old Feb 16, 2007 | 09:35 PM
VenomX-87's Avatar
lol that makes a lot of sence, keep the top one but get rid of the bottom one... err gust put some thick rubber hose where the bottom pads are ment to be once the top is in place it will push it down onto the rubber hose and it should hold it in place.
Old Feb 16, 2007 | 09:52 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Easy find, or make your own. If you cant locate the parts, try here:
http://www.tacreationsusa.com
Old Feb 17, 2007 | 03:46 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
WOW! That's a cool site.
eightsixseven
Dec 16, 2024 01:50 PM
Jeremys87
Jul 14, 2022 09:08 PM
Casey Meyers
Mar 2, 2016 10:46 AM
z28_AJ
Aug 27, 2015 08:59 PM
