Deleted AC years ago, want it back.
Old Nov 16, 2016 | 08:35 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
When I lived in Ohio, I removed the AC stuff. This was back in the 90's. Now I live in Florida and I am dying without it. All of the parts are long gone after moving about 4 times. What to do?
The condenser position is now occupied by a tranny fluid cooler. Even the AC lines are gone. And most of the brackets for the various AC components.
Old Nov 17, 2016 | 10:14 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Deleted AC years ago, want it back.
hit a jy for the stuff you can't get through rock auto?
Old Nov 19, 2016 | 07:44 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
I got a recommendation to install a Vintage Air unit. Does anyone have experience with these?
Old Nov 22, 2016 | 12:00 PM
prossi's Avatar
Im in the middle of doing it. I just pulled all the stock hvac from under the dash so I could measure what I could get in there. I will be ordering mine next week. Im going with the 68000-VUZ-A compac unit. I will be adapting it to the stock vents in the dash and use a sanden 508 compressor im also ordering a universal line kit so I can make all my own hoses/lines. haven't figured out the condenser size I want to go yet...that will be the next step
Old Dec 2, 2016 | 08:30 AM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
Does anyone have a diagram or pic of the system? I too want ac back. I need the cover that holds the blower motor and evaporator? and everything after. Condenser, lines,dryer etc
Old Dec 2, 2016 | 08:33 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Be a good time to also upgrade to a serp belt system as well.
Old Dec 3, 2016 | 09:30 PM
Drew's Avatar
No one reproduces the A/C hoses for 87, at least not for the TPI cars. There is a kit to convert to a Sanden compressor, but it looks fairly goofy since it has to be mounted far to the driver's side to clear the valve cover. Converting to the serpentine system might be easier, but the evaporator, high pressure line, hoses, etc are all different.
