Part number for original upper hose
Car: 1992 Chevrolet Camaro RS
Engine: 350 TBI
Transmission: NWC T5
Axle/Gears: 3.45 9 bolt posi
I dislike the routing Dayco came up with for my 92 RS 5.0. Anyone have the part number for the original hose or a better solution? I've tried the dayco, which I couldn't get all the air out of and a universal hose that doesn't fit without kinking up near the radiator outlet or the thermostat housing.
Car: `86 SS / `87 SS
Re: Part number for original upper hose
If it kinks up, perhaps shortening it would help. Some hoses are made a bit long. Which can be helpful, unless you're looking for a taught, clean fit. You should be running into 2 V8 hoses from each aftermarket mfgr. One TBI/4bbl, and one for Tennessee Porsche Injection.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Yep, the one that gt4373 pictured is the correct one. Should fit perfect
Engine: 350 TBI
I'll have to try that Gates hose. The biggest problem I have with the Dayco hose is instead of the hose sitting on the hose holder off the alternator, it runs up over top of the edge of the alternator bracket. I tried twisting it and tightening the clamp to no avail. I knew I should've kept my old radiator hose lol
Engine: 350 TBI
jmd, I shortened the universal hose as much as I could. Just to get around town until payday, I rerouted the hose around the alternator and over the engine hoist bracket. Still leaking and its rubbing on that bracket to boot.
Engine: 350 TBI
Yeah guys, the Gates hose is the correct routing. I feel the need to find out whoever makes Dayco hoses and tell them the one for our cars is incorrect. Thanks for the suggestions!
