NEED HELP WITH AC SYSTEM!
Old Apr 12, 2017 | 09:02 PM
JimRockford's Avatar
I just discovered today that the air conditioning system on my 1988 Trans Am has apparently been converted to r134a, as it has the red and blue plastic caps on the high and low pressure ports,and the low pressure side appears to have a quick disconnect style adapter. The AC system blows cool but not nearly as Cold as it should be in the compressor cycles on and off frequently. I noticed when removing the red high pressure, it makes a pressurized sound like opening a can of soda. I can also see bubbles coming from the Schrader valve when the Is removed. Is there a way to get a metal cap with an O ring that I can tighten down on that in place of the plastic To prevent the coolant from seeping out if I recharge the system?
Old Apr 13, 2017 | 06:25 AM
amfornal's Avatar
Car: 1989 IROC Z L98 G92
Engine: 5.7
Axle/Gears: 3.27 G92
Re: NEED HELP WITH AC SYSTEM!
I had same problem. With mine it was just a faulty Clutch Cycling Switch. Changed and now works fine.
Old Apr 13, 2017 | 09:22 AM
Did all the refrigerant leak out when you changed it? I believe the issue with mine is that it simply low on refrigerant, since it doesn't get as cold as it used to. Also when I removed the redcap I could hear a "psst" sound like it was under pressure. Has anyone here ever used a metal And O-ring to see you're a leaky Schrader valve instead of replacing it?
Old Apr 13, 2017 | 10:37 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
You can change the Cycle Switch, no problem. It too has a schrader valve in it to prevent losing the refrigerant. Check auto parts store for the caps. You can take a awl or small dowel and put it into the leaking schrader valve and do a "pop" with it. Compress it and release it. It may seat it better to seal. I had to do that with one of mine.
Old Apr 14, 2017 | 03:54 AM
Drew's Avatar
Just keep in mind it might not seal as well either. Had one once upon a time that had a sliver of steel jam in the schrader valve, holding it open. LOL
Old Apr 15, 2017 | 10:45 AM
Is a different clutch cycle switch required when converted to r134?
Old Apr 16, 2017 | 11:11 AM
JdubRS's Avatar
No. R12 and R134a operate at close enough pressures.
Old Apr 16, 2017 | 06:46 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
or get one of the Schrader valve tools generally used for car tires and see if the valve just needs to be tightened up a bit. Just stick it in and turn right...
Old Apr 16, 2017 | 07:48 PM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
They sell kits at the auto parts store. May have to change out the schader valve, oring might be shot or ripped. In the kits there are the large ones. Unfortunately u have to remove and reinstall ... then recharge.
