AC Compressor knock
Old Jun 27, 2017 | 03:12 PM
brianlibby791's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7L 350 TPI (Deleted Cats)
Axle/Gears: Original 3.27
AC Compressor knock
I just took the Smog pump out of my 89 GTA (TPI 350), car runs perfectly fine aside from when the AC is on, the compressor makes a knocking sound. I would assume it is a bearing inside the compressor itself? Could i just pull the clutch off and replace it?
Old Jul 3, 2017 | 01:53 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Who’s There ?
Depending on the former belt routing the A.I.R. pump acted as a vibration damper.
You want to check the bearings before assuming they’re bad.
The clutch bearing is near the clutch assembly and the rotor bearing is inside the compressor, however the clutch bearing is the more likely suspect.
If either of these is worn they can be replaced however the compressor is probably many years old at this point and won’t be long before you have to rebuild or replace the entire unit.
Happy Racing !
He Must Have Been Cheating - Because I Was And He Almost Beat Me.
Old Jul 3, 2017 | 11:22 PM
Re: Who’s There ?
Happy Racing !
would there be anything that i can do to get the vibrations that it now has since the removal to get it to go away?
Old Jul 5, 2017 | 11:38 AM
NINÅ's Avatar
Transmission: 765R4
Who’s There ?
Can’t think of anything besides a worn clutch bearing or loose hardware.
But you probably have made sure there are no loose mounting bolts, etc.
Happy Racing !
