fan "on" temp
Old Jul 18, 2017 | 08:25 AM
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
fan "on" temp
I used the search function but I'm still not finding what I'm looking for. the stock fan on my 305 tbi 1991 firebird comes on at 220 degrees. it gets over 100 degrees where I love and would like to make that fan come on between 190 and 200 degrees instead. is there a way to do this? I mean by resetting the temp on the ecu. I don't want to add a manual switch or anything like that. I want the car to do it.
Old Jul 18, 2017 | 09:32 AM
brett89's Avatar
Car: 1989 Trans Am GTA
Re: fan "on" temp
I would recommend you get in contact with Brian of Tuned Performance on this forum .. He can definitely help you out .
Old Jul 18, 2017 | 05:03 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
Re: fan "on" temp
The fan on your car is controlled by a switch that screws into the head. You can get one that turns on sooner. If you do this I would also recommend swapping the radiator thermostat with a 180.
https://www.summitracing.com/parts/jet-60600
Old Jul 18, 2017 | 06:00 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: fan "on" temp
Post #4
https://www.thirdgen.org/forums/cool...n-problem.html
Old Jul 19, 2017 | 10:02 AM
Evilokc's Avatar
Engine: tbi 305
Re: fan "on" temp
exactly what I was looking for. thanks guys. I was looking at the review on that fan tem switch and they are pretty bad. has anyone here used one? I ordered my o.e.m replacement radiator and am hoping to get it installed tomorrow.
