Single cooling fan problem
Old Jan 30, 2013 | 06:50 PM
eighty8's Avatar
Car: 1988 IROC-Z
Engine: 305 TBI
Transmission: TH 350
Background: My car is a 1988 305 TBI VIN E with a single fan and no A/C. When I bought it I was told the fan relay had blown and there was a switch under the dash to turn on the fan. The switch was connected to two wires that ran through the firewall to the pigtail which was unplugged from the relay. As far as I can tell, when the switch is closed power flows from the battery across the fan to ground making the fan run. I'm trying to return the car to stock and remove this very poorly wired switch.
Problem: I replaced the relay and warmed the car up to just over 105C (221F) and the fan didn't come on.
What I've tested: I jumped A and B on the ALDL still no fan. I heard some ticking from under the hood but it wasn't from the fan. Next I checked the resistance on the temperature sensor, the car had cooled some since the drive and as such the resistance was 401 ohms which seems right when I compared it with the gauge. With the engine running I disconnected the coolant sensor and the CEL came on. I also checked the fuse under the dash
My conclusion: The fusible link, fuse, fan and sensor are all working fine. The ECM is aware of the sensor and is receiving input. So the sensor gets hot and it's resistance lowers, the ECM interprets this and based on it's settings (which I can't check) sends a low amperage signal to the relay to open allowing high amperage current to turn the fan.
My question: why doesn't the fan turn on? Is there a way to test the wiring from the relay to the ECM? have I missed something obvious?
Old Jan 30, 2013 | 07:12 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Single cooling fan problem
on your tbi car the coolant temp sensor in the passenger side head grounds the relay coil at the specified temperature.
Old Jan 30, 2013 | 07:13 PM
Engine: Lb9
Transmission: M20
Old Jan 30, 2013 | 07:20 PM
Engine: Lb9
Transmission: M20
here is some napa part numbers if your switch is bad and you want to select a different on temp.
still haven't found an adequate fan switch. You might have to call up your local Napa to see if they have them.
MPE FS111SB On 245-Off 229
MPE FS112SB 229-Off 213
ECH FS111 On 220-Off 204
ECH FS112 On 229-Off 213
http://www.summitracing.com/parts/hyp-4028
http://www.summitracing.com/parts/hyp-4026
Old Jan 30, 2013 | 07:29 PM
eighty8's Avatar
Car: 1988 IROC-Z
Engine: 305 TBI
Okay cool, so if I wanted to test this I should unplug the sensor and jump the two wires or ground one of them?
Old Jan 30, 2013 | 07:34 PM
one92rs's Avatar
Car: SOLD!!!!!
just ground the wire going to the sensor ( single wire ) and the fan should come on.
Engine: Lb9
Transmission: M20
to test the fan switch and relay turn your key to the accessory position and ground the temp sensor wire. If the fan goes on you have a bad sensor. If it doest go on start testing the power and ground on the fan relay.
Old Jan 30, 2013 | 08:19 PM
eighty8's Avatar
Car: 1988 IROC-Z
Engine: 305 TBI
I'm looking at the wrong sensor. I was looking at the one next to the thermostat housing that has two wires coming out of it. I think I see the one you're talking about on the passenger side low down on the block but I'll have to wait till morning to see it clearly. Cheers and thanks very much for the help
chazman
Aug 28, 2018 03:25 PM
krisner89
Oct 10, 2015 06:03 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
chazman
Aug 22, 2015 02:01 PM
Leggman1
Aug 6, 2015 04:15 AM
