Overheating
Old Sep 11, 2017 | 09:27 PM
Jp's camaro's Avatar
Car: 1991 rs, 1985 z28
Engine: 3.1 v6, 305 tpi
Transmission: 700r4, 700r4
Axle/Gears: 3.23, 3.23
Overheating
91 camaro 3.1. The gauge shows its overheating but the coolant in the radiator is staying just a bit warm and the thermostat is opening. Any help would be appreciated thanks
Old Sep 12, 2017 | 12:54 AM
honestclay's Avatar
Car: 1991 custom camaro
Engine: 3.1v6
Transmission: automatic
Re: Overheating
is the gauge digital or analog ?
Old Sep 12, 2017 | 07:09 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Overheating
The factory gauges do interesting things, if you dont think it is actually overheating grab a new temp sensor and maybe an IR temp gun from harbor freight
Old Sep 12, 2017 | 10:15 AM
Re: Overheating
Its the factory analog gauges and the gauge wasn't working before so I replaced the temp sensor already and that's when it at least started working
Old Sep 12, 2017 | 04:20 PM
LiveIt!'s Avatar
Car: 1988 Camaro Sport Coupe
Engine: The All-Powerful 2.8l!! :P
Re: Overheating
How hot is "overheating "? These gauges can be a bit off, a cheap temp gun wouldn't hurt to double check
Old Sep 12, 2017 | 05:07 PM
Re: Overheating
I ran it till the gauge hit 240 in my driveway
Old Sep 12, 2017 | 08:14 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Overheating
Did your fan come on?
Old Sep 12, 2017 | 08:28 PM
Re: Overheating
Nope
Old Sep 12, 2017 | 11:20 PM
LiveIt!'s Avatar
Re: Overheating
Well something isn't working right
look at your fan relay on the firewall near the brake booster, it has rounded edges and 4 wires running to it. One is black with a red stripe, another is green with a white stripe, and I can't remember what color the other 2 are the point is run a wire from that green wire to a ground and turn the key ON. Your fan should come on now, and your problem is likely something with the temp switch....
best of luck
Old Sep 12, 2017 | 11:42 PM
Re: Overheating
It was wired to a toggle switch when I got it but when I pulled the old engine and installed the new one I ripped that out. Might just wire it back up that way. Thanks
Old Sep 13, 2017 | 10:18 AM
LiveIt!'s Avatar
Re: Overheating
I've seen some members wire their car with a switch and another generic relay, so that your fan system will still work stock, or you. can force it on with a switch
Old Sep 13, 2017 | 10:57 AM
Re: Overheating
Yeah I've seen that too, it was wired with a switch so I'll probably do that again
Old Sep 13, 2017 | 04:21 PM
LiveIt!'s Avatar
Re: Overheating
Sounds good I like having my car that way, runs half as hot as it should lol
Old Sep 13, 2017 | 10:56 PM
Re: Overheating
True lol, I'm still wondering why the coolant in the radiator is staying cool enough for me to put my finger in it after the thermostat has opened tho
Old Sep 14, 2017 | 03:20 PM
LiveIt!'s Avatar
Re: Overheating
I never tried touching it hot, I'm just happy enough not seeing smoke billowing out the hood
Old Sep 14, 2017 | 04:25 PM
Re: Overheating
Lol I had that too as I've slowly been bringing her back to life
Old Sep 15, 2017 | 01:44 AM
LiveIt!'s Avatar
Re: Overheating
Haha that was me when I first got my car, it was so much fun bringing her back to life! When she wanted to die on the side of the road, not so much
Old Sep 15, 2017 | 09:30 AM
Re: Overheating
Lol she's still got awhile before she's road ready, but it at least runs now. It sat for like 12 years before I bought it
Old Sep 15, 2017 | 12:36 PM
LiveIt!'s Avatar
Re: Overheating
It's getting super off topic here so I sent u a msg
