A/C Sensor Bench Testing..
Old Dec 4, 2017 | 10:14 AM
ronkay's Avatar
I have a 92 with a 305 and have just replaced the entire A/C system. However before charging the system I'd like to test two the last two systems sensors.
1. The first sensor is located on the compressor and has what looks to be a white (actually discolored off white) two pin plastic connector base. It's referred to as a "Compressor Mounted High Cut-Out Pressure Switch" 4-Seasons number 35974. Picture attached.
2. The second sensor is referred to as a "Condenser Fan Switch". It's located on the high pressure aluminum liquid line running from the condenser to the evaporator. It screws onto the line via a schrader valve. Also a two pin connector.
Can these sensors be bench tested? If so how?
I've attached a couple of pictures...
Any information would be much appreciated
Thanks,
Ron
Fan Control high press line
High Press sensor
Compressor Sensor
Business end of sensor...
Mounting on compressor rear...
Old Dec 4, 2017 | 11:06 AM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Re: A/C Sensor Bench Testing..
You could test then with air pressure but the challenge is a jig to test then with. For how cheap they are I would just buy new ones...
