Dual LS1 Fan issue: 1 EBL ECM Fan / 1 Head temp. / EBL
Old Dec 13, 2017 | 12:20 PM
Napster134's Avatar
Car: 1991 Pontiac Firebird
Engine: 355 TBI
Transmission: 7004R
Axle/Gears: 3.27/42 ?
Hi all,
Recently, I've been having an overheating issue in stop/go traffic. The temps start to creep up slowly and eventually I'll end up in the red zone (on the stock temp guage)
I never have any issues when driving on the freeway. I suspect it's related to my fan setup:
  1. I have the dual LS1 fans.
  2. What I know at a high-level view:
    • 1st fan is triggered via my EBL ECM (or at least it's supposed to be)
    • 2nd fan is triggered via the head temp switch (or at least it's supposed to be)
    • I suspect one or both are not working when they should.
    • When I turn on my A/C, my driver side fan turns on, however, the "Fan" box in EBL WUD does not turn on.
  3. What I don't know at a more detailed level:
    • One of my fans is connected to a relay that I wired a few years ago.
    • I have no clue how or why I wired it this way but I'm pretty sure I followed some sort of wiring diagram/tutorial
    • I believe this relay is triggered via my EBL ECM but haven't traced my wiring just yet to make sure.
  4. Last night I found that the A/C switch would trigger one of the fans.
    • I took the car out for a drive and let it get to the middle of temp guage.
    • As soon as the middle was reached I turned on the A/C.
    • Temps began to decrease to normal.
    • This is why I suspect a fan malfunction.
Here are my questions:
  1. Is there anyway to force enable the (supposed) EBL controlled fan by changing a parameter/value?
    • I wanted to try this to test the EBL controlled fan.
  2. What would be the best way to test the non-EBL controlled fan?
    • I've already checked that my head temp fan switch is connected and in tact.
    • I was going to swap the connectors on each fan to test each via the A/C trigger but found I would need to get under the car and it was getting late.
Old Dec 13, 2017 | 03:12 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Dual LS1 Fan issue: 1 EBL ECM Fan / 1 Head temp. / EBL
For the fan controlled by the switch, you can just ground that wire, since that is what the switch does.
Both fans should be wired through a relay though, so if they're not, you should add them
Old Jan 22, 2018 | 08:32 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
AC could engage both fans.
Have you run 12v power directly to both fans to make sure they work? I know you said one works so just the other would be needed I guess. This will eliminate the fan motor being an issue anyway.
Old Jan 24, 2018 | 01:41 PM
Napster134's Avatar
Engine: 355 TBI
Transmission: 7004R
Hi all,
Ended up fixing this.
Each fan had it's own reason why it was not engaging:
1st fan (EBL controlled) was not tuning on because I wired the IGN to a dual fuse holder for my radio (http://a.co/bLOmzww) and had removed one of the fuses which I forgot to put back. Once I replaced the fuse then it started to work.
2nd fan (Head Fan temp. switch controlled) was not turning on simply because my fan switch was toast. I replaced it with the 87 regal one that turns on at about 212F.
Now they both work when they should
Thanks for all the replies everyone!
Old Jan 24, 2018 | 03:06 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Good to hear you got it fixed!
W.E.G.
Aug 20, 2017 09:50 AM
aziroc
Jul 19, 2002 02:44 PM
Biochem
Apr 18, 2001 12:45 PM
