89 IROC 5.0L TPI Rad Coolant Reservoir part number question
Old Feb 14, 2018 | 09:51 AM
Rustynut55's Avatar
Car: 89 IROC Convertible
Transmission: auto
Hi, I have an 89 IROC 5.0L TPI auto convertible with a cracked radiator coolant tank. The existing radiator coolant tank part number moulded in is "10077293, ASM 10077291, made in canada". I find adds stating that the part number is 10170175. Any ideas why the part number on my existing tank is different?
Attached Thumbnails 89 IROC 5.0L TPI Rad Coolant Reservoir part number question-89_rcr_label.jpg
Old Feb 14, 2018 | 10:07 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 89 IROC 5.0L TPI Rad Coolant Reservoir part number question
Part numbers sometimes get updated through time, maybe a supplier change or who knows but the "new" NOS ones I have gotten aren't date coded like your original one .
Old Feb 14, 2018 | 10:15 AM
Rustynut55's Avatar
Transmission: auto
Interesting. I found this on GM parts WIKI "RETAINER RR BPR FASCIA SUPT PUSH IN 01 276 PG7 20 12 82 87 A 10077293 AR 32 RETAINER RR BPR FASCIA" Maybe duplicate numbers somehow?
Old Mar 1, 2018 | 08:11 PM
Rustynut55's Avatar
Transmission: auto
I decided to keep the OEM if possible. Bleached the tank with Clorox, Oxyclean, a little Dawn and a bunch of BBs. Changed the solution twice over a soaking period of about 4 days. Don't have a beginning photo but did get most of the yellow out. Welding the plastic seemed to work well with the exception of the crud in the crack staining the melting plastic. I tested the tank with boiling water and it proved water tight. One photo shows the weld and the second shows an interior view of the crack. Interior view
plastic weld result showing staining from the crack contamination
overall view
JamesC
Mar 22, 2026 09:55 AM
Mark_ZZ3
Jan 30, 2025 01:34 PM
4mul8r
Oct 11, 2018 08:44 AM
tglennon11
Members Camaros
67
Jul 22, 2017 10:59 AM
