Upper radiator mount for bigger radiator
Old Apr 1, 2018 | 05:48 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
Thought i'd share some info for those trying to run a bigger (thicker) radiator and the upper radiator mount doesn't work with it. the 2nd gen camaro upper mount is a direct fit with stock mounting hardware and holds the radiator nicely and looks good while doing it. part is available new at summit for $21, part # SUM-G3920B
edit: oem fans may not work with this setup, the top bolts go to the original upper radiator mount. but then again the oem fans dont pull enough air to accommodate a big radiator like this.
Attached Thumbnails Upper radiator mount for bigger radiator-radiatormount1.jpg   Upper radiator mount for bigger radiator-radiatormount2.jpg
Old Apr 2, 2018 | 01:17 PM
howy03's Avatar
Car: 1985 Pontiac Trans Am
Re: Upper radiator mount for bigger radiator
I second that!
Old Jun 2, 2018 | 10:35 AM
Boom's Avatar
Car: 1986 Iroc
Engine: 383
Thanks for posting this! What are you guys using for the rubber insulators?
Old Jun 2, 2018 | 11:18 AM
howy03's Avatar
Stock bottom and I made custom top out of a cheap set of coil spring spacers (generic from pep bots I think )cut in half long way then trimmed out w dremol tool
Old Jun 3, 2018 | 03:43 PM
Randy_M's Avatar
Car: '92 RS Camaro
Engine: '92 SD 305 TPI
Transmission: BW 5 speed
Axle/Gears: Stock Open 3.08:1
Next big question, what radiator is being used?
Old Jun 3, 2018 | 04:06 PM
howy03's Avatar
It’s a champion w electric fans.from eBay
Old Jun 6, 2018 | 10:46 PM
QuickStyle's Avatar
Car: 91 Z28
i used a griffin universal 31x19 radiator. and summit brand dual electric fan with shroud part # SUM-G4850
JPB
Jan 13, 2014 11:23 PM
fireturd350
Fabrication
May 7, 2010 07:24 AM
fireturd350
Fabrication
Apr 11, 2010 06:52 PM
jtmiller92
Exterior Parts for Sale
Jan 28, 2008 12:15 AM
Steve00YZF
Jan 18, 2001 12:34 AM
