No ground for cooling fan
Old Apr 25, 2018 | 07:16 PM
borneobuzz's Avatar
Hello, All!
1987 IrocZ with 5.7 TPI. I have tested entire cooling system, and am down to what actually controls the grounding for fan solenoid... When I jump A & B in ALDL the fan will turn. When up to temp, no ground to fan solenoid. I have swapped computer, but not the prom or "chip". Could it be that? Getting a little frustrated, and could use your experience and help! Thanks for responding!
Old Apr 25, 2018 | 10:36 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: No ground for cooling fan
Originally Posted by borneobuzz
Hello, All!
Any codes 15 ?
Fan solenoid do you mean the fan relay ?
Old Apr 26, 2018 | 12:52 AM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Fan switch in the block is the ground for the relay
Old Apr 26, 2018 | 02:29 AM
Drew's Avatar
Fan turn on temp is 16 billion degrees Fahrenheit, are you letting it get hot enough for the fan to kick on? Actually it's only 230* +/-. With the airdam and a 180* thermostat, about the only time the fans on my thirdgens ever kicked in, was after relatively hard driving, in hot weather, and then suddenly being stopped, like in a drive-thru or bumper to bumper traffic jam on the interstate in a busy city.
Old Apr 26, 2018 | 05:05 AM
borneobuzz's Avatar
The cooling fan was working properly, then inop. From what I understand the computer needs forward speed less than 40 mph and temperature signal to turn fan on. I could wire in manual switch, but want to keep it clean. Any more thoughts????? Thanks for responding!
DustyWusty
Jul 2, 2004 06:23 PM
MTPFI-MAF
Feb 14, 2004 05:44 PM
aziroc
Jul 19, 2002 02:44 PM
Stuart S
Aug 8, 2001 09:00 PM
