Fuel tank pressure
Old Jun 14, 2018 | 09:44 PM
GTAguy549's Avatar
Car: 1991 Pontiac Firebird GTA
Engine: 305 TPI 5.0L
Fuel tank pressure
I have a 1991 Pontiac Firebird GTA. After 30 minutes of driving at regular summer temperatures, when I stop at a light or intersection my car idles way down to around 300 - 400 rpms and almost stalls. It is a 305. 5.0L fuel injected engine. If I pop it in neutral it will rev back up to normal. When I got home I released the fuel cap and a gush of pressure released, enough for the cap to pop out into my hand. Anyone out there in the bird world have any info on this?
thanks
Old Jun 14, 2018 | 09:49 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Dual rad fan issues
Are they turning on when warm 226f ?
There is a speed cut off for the fans above 35mph if I recall.
If the ecm controls the relay with the ecm in field service mode you might have a bad ecm. Just a guess.
Old Jun 14, 2018 | 09:51 PM
Engine: Lb9
Transmission: M20
If your dealing with tpi here is a schematic of the fans.
Old Jun 14, 2018 | 09:57 PM
GTAguy549's Avatar
I'm not sure what the temp would be, seems strange driving for 30 minutes and don't hear them.
speed cut off above 35 mph? So at 70 on the Hiway they won't run?
Old Jun 14, 2018 | 11:39 PM
Drew's Avatar
The fan is only necessary when the car is stopped. The rest of the time, the airdam under the radiator support pushes air through the radiator, no need for a fan when the car is moving.
Old Jun 15, 2018 | 06:51 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
following the attached schematic, there is no speed cut off for the secondary fan.
Old Jun 15, 2018 | 07:35 AM
GTAguy549's Avatar
good info to know Drew, thanks pal.
Old Jun 15, 2018 | 03:32 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
Research here on normal fan operation. Is it just working normally? There are temp sensors that can go bad. Seems fan motors are ok.
Old Jun 15, 2018 | 04:49 PM
GTAguy549's Avatar
i took it out out for a drive the other day for about 30-40 minutes and it was 28 degrees Celsius outside. When I returned home I left it running in the driveway for another 15 minutes and the fans didn’t activate.
not sure what’s going on there.
Old Jun 16, 2018 | 04:52 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
So is the car overheating or not? Scratching my head wondering what actual problem you're trying to solve.
FWIW - I can't hear my fans when they run but my car is kind of loud.
Old Jun 17, 2018 | 11:27 AM
GTAguy549's Avatar
sorry, the car is not overheating. The fans didn’t seem to be coming on but I guess the engine just wasn’t getting hot enough. I stopped in my driveway today after coming back from a drive and let it idle until the fans kicked in.
seems to be working fine now, yay!!!
thanks everyone for your interest in helping though.
Old Jun 19, 2018 | 06:13 PM
GTAguy549's Avatar
New problem.....
thanks
Old Jun 19, 2018 | 06:22 PM
Engine: Lb9
Transmission: M20
Re: Fuel tank pressure
https://www.thirdgen.org/forums/tpi/...eat-blues.html
You might clean your ufo as the call it valve.
I’m not sure that is your solution but maybe clean your iac.
Mark_ZZ3
Jan 30, 2025 01:34 PM
Alaska Hwy 1Le
Jan 2, 2017 04:30 PM
IROCZ1989
Aftermarket Product Review
25
Oct 27, 2016 12:36 PM
RE849
Sep 18, 2016 08:20 PM
Tibo
Sep 14, 2016 08:19 PM
