Need help with A/C compressor clutch coil
Old Jun 15, 2018 | 12:20 AM
JoJoMix's Avatar
Hello everyone,
I have a problem with my Dodge challanger 2015 with AC problem as it was not cooling. Took it to a mechanic, a friend of mine, to fix it and he doubted the clutch coil is the problem. He disassemble the A/C and took the compressor out to test it. Not sure why he wanted to test the compressor clutch by connecting 12v directly through the clutch terminal (a plug with 2 pins) and he somehow burnt the flywheel diode that protects against the surge. I knew after reading though forum that clutch coil doesn't have a polarity and in case a diode exists, it would be installed in the harness. Seems like newer clutch have built-in diode or thermal fuse and that got burnt just because my friend didn't bother check polarity first.
Now the old clutch with burnt diode is shorted so coil would heat up where usually from what I searched if diode is damaged it would be open and compressor clutch would work normally but only the problem of voltage spike would occur. Mine just complete short circuit at diode.
I went and bought a used clutch but got promised that it works. The one I got has green/black wire to harness while old one was white/black. The clutch is the same but the harness is different and not sure how to first test it and how to connect it. Is the green +pos and black -neg
I put picture comparing both old burnt coil and the supposedly working one. I did try diode test using a multi-meter but I get a reading of 0.05v on both sides of terminal. Also when trying ohm test the reading fluctuates alot (maybe because i'm testing a magnetic coil) till it settles to 3.4 ohm and the same reading if I switch polarities.
So I got nothing from the multi-meter to indicate the diode position as I do not want it to get shorted while testing.
a ceramic diode was in the burnt coil
Old Jun 15, 2018 | 09:19 AM
Go Blue's Avatar
Re: Need help with A/C compressor clutch coil
Did he ever check the level of the R134a? All cars have a high pressure sensor and a low pressure sensor in the AC line somewhere that are there to protect the compressor from being burned out and that would have been a couple of easy checks to do before checking the clutch on the compressor. I would want to know what checks he did before going to the compressor clutch. I don't remember how to check the clutch coil without doing some research first, but I would have ruled out a lot of other things before I went with the clutch and coil. Sorry, i'm not much of an overall help, but if he shorted it doing the check, then he should be the 1 to replace it at his cost.
Old Jun 15, 2018 | 04:34 PM
JoJoMix's Avatar
Thanks for the info,
I guess I will have to ask him to replace it with a new one then
Green89IROC305
Jun 6, 2006 11:32 PM
grafx
Apr 2, 2003 06:04 PM
eightTfourTA
Jul 16, 2002 02:57 PM
