AC Compressor seized after fresh R-12 charge Tips for proper compressor swap, please
Old Jun 26, 2002 | 09:31 AM
KED85's Avatar
I'm going to obtain the rebuilt compressor.
I'm having my system evac'd today.
Besides the obvious (new belt, compressor swap, lube o-rings or ?)
Need I seek out and replace the Expansion Tube (Orifice)?
I never saw the AC system hoses open.
Look like they never were, also.
I just had evac'd and recharged.
Two days later....
Oh well, that's racing....
Tips, thanks!
I got tips.
Salgado - $165 compressor
Unique Auto Exchange - $140 compressor (East LA, also). Good thing is they also sell the Smog Pump I need for my Blazer at $25!!
CAN YOU SAY BEST BREAKFAST BURRITOS! OLE!
BUMMER
I need purchase the expansion orifice and the accumlator tube, too. Gotta find those now...
AH the price of avoiding new car payments!
Anyone want to buy a factory fresh/ram air set up for a Camaro?
Fresh repaint, behind front nose side panels, air filters, that thing between radiator support and nose, shiny Dzus fastners, all the stuff. Looks brand new.
Email for pics...
I need $ome repairing ca$h!
Old Jun 26, 2002 | 02:09 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Why would you need the expansion orifice? Isn't that the piece in the a/c hard line, located on the passenger side's main frame rail? And what piece is the accumulator "tube"? Do you mean the whole silver accumulator? JCWhitney's sells 'em for $20.
Old Jun 26, 2002 | 07:40 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
When I put a new compressor on 2 months ago, i replaced the orifice tube and the accumulator, also.
It's pretty straight forward. My GM/Harrison compressor didn't come with oil so we had to find out the exact amount of PAG oil to add (forgot the amount....8 oz.?????). Other than that, it's easy.
I paid $220 for a GM compressor, accumulator, o-tube and some r134.
Old Jun 26, 2002 | 08:30 PM
WaynesRS's Avatar
This is prabably a stupid question guys , but , What are all the parts with the AC ? ....B/c a few weeks ago we had my Moms compressor changed on her car , it was $850 ..parts and labor . But another shop quoted us $1500 !!!! I could not belive that the same shop 3 years ago put a whole new AC in my car for $900 ...
Karl ,
They also changed those other parts on my moms car .So it must be a standard procedure . My uncle was telling me it has something to do with part of it being contaminated with particles from the old ac . Something like that , i dont rememver his exact words .
Old Jun 26, 2002 | 08:49 PM
Engine: LH0 3.1L
Well, the orifice tubes do get "plugged" up after time. As for the Accumulator, GM actually recommends replacement every 5 years but NOBODY does it.
If you came in to my work and had the Compressor, Accumulator and o-tube replace, plus freon re-charged.....I'd guess at around $900 in PARTS ONLY. Plus labor of 3-4 hours....$1200 easy. I don't know how people afford it. Maybe it's America's addiction to credit. Just today i replaced a fuel pump module on a 98 ******* Van....$688 for the fuel pump ONLY. Plus 3 hrs labor.... ~$1000. I could replace my fuel pump for $65.
Old Jun 26, 2002 | 10:02 PM
WaynesRS's Avatar
hahaha ..lol lol ..im laughing my *** off ..******* van !!! wait we can say *** on here ? .
Old Jun 26, 2002 | 11:01 PM
KED85's Avatar
I see a Monty Python skit coming on now.....
Yeah I was told dryer & orifice & then system is good.
I'm happy the "AC Radiator" didn't have a pin hole in it.
Before I had this car, it was involved in a front end accident.
Not a big deal at all this AC rebuild, but, drag is that of course that AC belt is the last one!
There a place close by that has the stuff (o-ring, oils orifice & dryer).
I got a name in Torrance, also.
There is also my Business Yellow Pages (vintage 1995 Los Angeles).
Hope to have this AC going by Mon.
Really felt like a king, stuck in LA traffic, KLON 88.1 Jazz Radio & relaxing, cool.......
My Helms fctory shop manual book has the oil quantity amounts Dan.
Love having those books as reference.
Old Jun 26, 2002 | 11:21 PM
Xenodrgn's Avatar
Karl, would you be kind enough to post those exact amounts to fill a completely empty system?
I just today found out my compressor is shot, so I'm going to have to plop down some money to have it taken care of. I'm pretty sure I can replace the parts, but the refilling I'm uncertain about...
Perhaps I'll have to look into those DIY recharge kits...
Old Jun 27, 2002 | 10:42 AM
KED85's Avatar
I have the S-10 Blazer Helms book by me
This is the reference I quote.
Will be same for 3rd gen's?
Most likely almost exact oil usage...
FOR R-12 ONLY!!!
Use 525 viscosity refrigerant oil
I'm going to highlite quantities & parts.
Alot of typing & I must do things today.
BUT this is an education for myself, also.
let's go...
Discharging the CCOT AC System
When system dischagrged, measure record amount & discard the collected refrig oil (I had mine evac'd by modern system, so no knowledge how much I had).
IF quantity is 15 ml (1/2 oz or more) this amount of new 525 oil must be added to system
IF adding oil is necessary, remove the suction hose at accumlator outlet pipe connection & pour correct amount in hose or pipe, then reconnect (new o ring & proper torquing connections)
Meaurements (from the book)
R4 compressor (is what we tend to have under our hood, small, short round) - 180 ml (6 fluid ounces)
NEW oil quanitites must be added to the system during component replacement & condtions stated as follows-
WHEN THERE ARE NO SIGNS OF LEAKAGE...
Compressor -Remove, drain measure, replace same amount + 1 oz (above says 6, I am swapping out old for new rebuilt, I'll add 6 oz)
Evaporator - 3 oz (not touching
Condensor - 1 oz (not touching)
Accumulator-(I am replacing this)- remove, drain oil, replace same PLUS 2 oz for dessicant (that retained oil, soaked it up).
Only other connection I touch is the orifice (particle filter unit)
NOW....
Accumulator (I'm replacing)
R-4 Compressor system
IF new accumulator, fluid added must be 2 oz additional oil (to what poured out from original item).
Charging, usually 4 pounds.
Does this assist?
Is evaporator in the car interior at firewall - YES
Is condensor at the front at the radiator? - YES
Good luck too!
Reddeath210
Oct 6, 2015 08:20 AM
dutch930
Sep 11, 2015 06:58 AM
TheExaminer
Aug 25, 2015 07:34 PM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
