Replace Heater Core or Repair Original One?
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
I am going to be repairing my heater and I expect that my car has the original core in there. It is leaking into the passenger floor foot area when the heater runs. I have shops nearby that can repair it rather than I buy a new replacement. Is the OEM heater core better quality than replacement ones today? Is it too old?
Re: Replace Heater Core or Repair Original One?
But that's just my thoughts....
It would depend on where it's leaking... If the core is corroded away, a repair would be costly. If it's leaking at one of the joints, around the end caps or the inlet/outlet tubes, it'd be easy to clean up and solder the joint closed again.
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
I’d fix the original if you can. The tubes on replacement ones don’t fit like the original. The tube bends on some are way off.
Engine: 350 TPI L98
Transmission: WC T5
Thanks. I will try to repair the original one.
blue86iroc
Mar 27, 2004 09:40 PM
a1987formula350cu
Dec 24, 2000 03:22 PM
