Cooling fan won’t turn on...
Old Nov 10, 2018 | 09:15 AM
Firebird2011's Avatar
Car: Pontiac Firebird Formula
Engine: 3.1 LH0
Axle/Gears: Automatic
Ok, today I took the car for a ride. Once stuck in a traffic jam the engine temp was climbing, and the fan didn’t switch on. I stopped the car to cool down it and I drove to the garage. If I jump the terminal A-B in the ALDL socket the fan doesn’t start. The engine is a 3.1 V6 Lh0. How can I do a fan test?
Thanks!!
Old Nov 10, 2018 | 01:03 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Cooling fan won’t turn on...
Probably first check the fan relay and see if it looks burnt on one of the terminals. If that's good put 12 volts on the fan to verify if it's working. Does it work when you switch AC to on?
Old Nov 10, 2018 | 05:43 PM
Engine: 3.1 LH0
I still haven’t tried, which one is the fan relay on the firewall?
Old Nov 10, 2018 | 07:07 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I have a Camaro not sure where on FBs. You could follow the wiring back from the fan. The relay will have only four wires going to it, two big ones for power in and out, and two small ones,
one for 12 volts with key on and one for the ground trigger from either the fan switch or ECM whichever yours uses
Old Nov 12, 2018 | 08:04 AM
Engine: 3.1 LH0
Thanks henry, I just jumped the two red and black red wires from the connector: the fan starts up and the fuse is ok. Maybe a relay issue? Or a bad connection to the dkgry/white wire? Can I chack it easily? Maybe the coolant sensor?
Old Nov 12, 2018 | 02:58 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Old Nov 12, 2018 | 06:20 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Old Nov 13, 2018 | 08:36 AM
Engine: 3.1 LH0
Fantastic, I really appreciate your help!! Now it’s crystal clear!! Thank you guys!
Shane4524
Sep 24, 2021 02:32 PM
Fronzizzle
Jul 20, 2017 02:18 PM
bbsr72
Oct 1, 2007 03:49 PM
kmdracer
Nov 25, 2002 01:53 AM
